Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 3rd February 2012, 11:20 AM   #1891
Corpius is offline Corpius  Netherlands
Corpius's Avatar
Originally Posted by mr_push_pull View Post
so that's another proof why single ended (RCA) connection is a bad thing?
Lets put it another way:
I totally agree that females should have inputs
Old 3rd February 2012, 01:38 PM   #1892
Speedskater's Avatar
Jim Brown also covers the interconnect situation in some of his papers:
Audio Systems Group, Inc. Publications
Look for "pin #1 or SCIN).
Bill Whitlock also has some papers:
JENSEN TRANSFORMERS, INC. - APPLICATION PAPERS AND SCHEMATICS
Kevin
Old 3rd February 2012, 09:32 PM   #1893
Tymen is offline Tymen  Netherlands
Smile Linkwitz Orion and Ncore
Originally Posted by Corpius View Post
I live 2,5 miles from hypex (de Weijert). But I do not think that the modules will be here sooner, unless they start bringing them personally.
I'd better start buying the the remaining needed parts.
Hi there, I also live 4,7 km from Hypex, Noorderplantsoen Groningen.
I'm currently building a pair of Linkwitz Orions v3.5 using the new Seas woofers. For this system I'm eagerly saving money to buy a good 6- or 8-channel amp. I'm hoping the NCore amps will be within reach of my budget. However with 400 watts I'm also concerned to burn my expensive tweeters in case of a power dropout or something else causing serious interference.
Therefore I have 2 questions:
1) is it possible to reduce the NCore's power in order to reduce the chance of damaging the tweeters?
2) how much smps's are needed to power the Orion loudspeakers? One loudspeaker has 2 woofers (10 inch), 1 mid (8 inch), 2 tweeters? Is one SMPS per loudspeaker enough?
Old 3rd February 2012, 10:10 PM   #1894
Hi Tymen,
I still win with 3 km
For the woofers UCD's in stead of ncore's will be more than sufficient (following Bruno's advice...) and will save you quite some money.
Actually a UCD180 will do, as you don't need more power even for the Orion equalized bass (open baffle bass takes less amplifier power than you think; I remember that Linkwitz mentioned 60 watts to be enough).
Extra quality of ncore amps should be apparent in mid and high. The datasheet tells you how low the power supply voltage can be.
I estimate that with a low supply you will still have a 100 watt at 4 ohm amp (tweeters parallelled).
I am about to start building open baffles too, but my approach is a bit different (high efficiency speakers with low power class A amplifiers).
Old 5th February 2012, 02:16 PM   #1895
elviukai's Avatar
That's right, best to use female imputs and I totally agree with you that inputs should be female.
its only yours opinion. I bet Ricky Martin and Elton John will strongly disagree with you on that bold statement
natural sound reproduction from traditional dynamic drivers?!! come on.. no no, it can be.. it must be!..
Old 5th February 2012, 02:36 PM   #1896
This thread is entitled 'hypex ncore' not 'schoolboy smutty innuendo'!!! C'mon chaps.....
Old 5th February 2012, 05:43 PM   #1897
Ricky Martin & Elton John? Why bring a woman's perspective into the discussion.
Old 5th February 2012, 06:00 PM   #1898
Send a message via Yahoo to mr_push_pull
yeah, digging up the two listening reports will get even harder.
"This site gives off very confusing signals, one minute highly technical discussions that leave the truly interested learners wallowing in their own stupidity and the next finds it endlessly repeating old wives tales and cockeyed theories as fact."
Old 5th February 2012, 09:14 PM   #1899
...with 400 watts I'm also concerned to burn my expensive tweeters in case of a power dropout or something else causing serious interference. Therefore I have 2 questions:
Lowering the amp power is not a good idea, and only in the extreme rarest failure mode would protect your tweeters. More often the *lower* power would damage them via clipping. Anyway woofers are at the most risk in amp or power failures, and Hypex has good protection circuits. However, the ncores are DC-coupled (yes?) unlike the stock UcD, so require more care in the protection area; not sure whether they have additional protection circuitry for that reason.
EDIT: I think your best protection actions would be strong surge protection for all the electronics, but especially for the active crossover.
Originally Posted by pieter t View Post
Hi Tymen...For the woofers...a UCD180 will do, as you don't need more power even for the Orion equalized bass (open baffle bass takes less amplifier power than you think; I remember that Linkwitz mentioned 60 watts to be enough)...Extra quality of ncore amps should be apparent in mid and high...
Tymen has a pair of 10"s on each side, if he plans to use them at high levels sometime, he should have more than 100w for each bank. Also, I don't know the impedance of that part of that speaker, if it dips below 4 ohms anyplace he should consider the ncore instead because of its 2 ohm near-perfect voltage-source performance, IMO. He'd probably be fine with UcD but might get better sound with ncore even in the low band. Another consideration is that the amps should last many years, why underpower a future speaker like an ATC, etc?
EDIT#2: From the Linkwitz website"
"...If the two 10" drivers of the woofer are connected in parallel, then they present a low 2 ohm impedance to the power amplifier around 100 Hz. The power amplifier driving this load must be capable of at least 200 W into 4 ohm. I prefer separate, lower power amplifiers for each 10" driver..."
You can thank me later... 8P
Cheers
Old 5th February 2012, 09:40 PM   #1900
Hi Sam Lord,
Two remarks:
- a lower power Ncore will put out some 100 watts at 4 ohm when I check the datasheet well; do you think that this power will drive a pair of tweeters (crossed over at some 1500 Hz) into clipping before you already killed your woofers and mids when trying?
- UCD180 delivers the more than 100w at 4 ohms easily. When you would have followed the thread you might have remembered Bruno Putzey's opinion: ncore does not better UCD in the bass department. "Underpowering" multi-amped speakers systems with hundreds of watts of class d power for future speakers? You'll be deaf by that time...
Currently Active Users Viewing This Thread: 4 (3 members and 1 guests)
leedle, tony399, jeno
Hypex problem, who can help Hansms Class D 8 10th March 2011 08:18 PM
Hypex steveww Class D 14 18th November 2010 01:44 PM
Question for those who have tried hypex smps with hypex modules avian Class D 12 3rd March 2009 09:30 AM
Hypex UcD 180AD + signal wires, Power Supply ST, Hypex Transformer TR100A c10h12n2 Swap Meet 7 7th July 2007 03:55 PM
FS: Hypex UcD 400/180AD, hypex toroid Archmage Swap Meet 4 14th November 2006 04:23 AM
Page generated in 0.18813 seconds (38.88% PHP - 61.12% MySQL) with 11 queries
