KT88 SE Basic or Master Kit - Page 3 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 25th February 2011, 12:19 AM   #21
Originally Posted by REDHORSEMAN View Post
I have just an hour of listening time with this amp so I haven't criticly compared this amp with my other kit amps.
The speakers I used are frugal horns that I purchased as a flat-pack with a pair of enabled fe126 fostex drivers,the bass is augmented with a pair of subs.
As far as hum and noise this amp is dead quiet to my ears
I would like to put together some new speakers for this amp any recomendations welcome
Bob
Hi Bob,
I designed these speakers specifically for this amplifier. They are about 98dB efficient. It is a 2-way bass-reflex design using the Eminence Deltalite II 2510 woofer and the Ciare 1.38TW horn tweeter. I designed the crossover with a Zobel network for the woofer and a compensation circuit along with required attenuation for the horn tweeter. They have a very live sound, actually they are awesome. It's like the performers are in the room with you. They are pretty flat all the way down to about 48Hz. The first set I built uses the traditional "monkey coffin" design, however I have redesigned the cabinet to be a more contemporary floor-standing version. I have not built the floor-standing design yet, but it should be exactly the same just not needing a stand to elevate them to ear level. I hoping to have the new version built in a couple of months as time allows. Let me know if you are interested.
I want to add that these loudspeakers seemed to take about 50 hours or so to "break-in". The low-end and tightness improved dramatically after running these for a while at relatively loud volume.
Scott
Old 25th February 2011, 02:11 AM   #22
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Scott
with a 10" woofer
most likely max 95db
but hey, 95db, that would still be ok
Old 25th February 2011, 09:19 AM   #23
Originally Posted by tinitus View Post
with a 10" woofer
I believe these to be a little closer to 98dB like I originally stated. The woofer is rated at 97.3dB and the bass-reflex cabinet design affords about another dB increase in sensitivity.
Old 25th February 2011, 10:51 AM   #24
Since sensitivity and efficiency are not synonymous, I should have stated "sensitivity of about 98dB" not "98dB efficient" in my original post describing these speakers. I suppose I had an "old-timers" moment.
Old 25th February 2011, 11:00 AM   #25
on paper, yes
and at a certain frequency
look at 500hz, or so
then ususally a different picture
I didnt even mention BSC
baffle step compensation
which means SPL loss below 500hz
compensation is done by attenuating above 500hz
subtract that, and it could be even lower than 95db
but I didnt
a calculator will also tell you this
even much bigger woofers often ends at 96db
does it matter
I dont know
but it is partly about whether a speaker sounds 'thin' or 'full'
maybe you compensate some by using tube amp, etc
and not to forget the bigger front baffle
Old 25th February 2011, 01:25 PM   #26
Thanks for your comments.
I did not use a BSC circuit in the design of these loudspeakers. Based on my calibrated measurements and frequency response testing, this is not required and would only offer detrimental effects.
on paper, yes
but I didnt
does it matter
I dont know
Old 25th February 2011, 06:43 PM   #27
on paper, yes
but I didnt
does it matter
I dont know
Now you've got me curious. I'm going to have to set up my test bed again and measure as you suggested. Thanks again.
Old 27th February 2011, 02:00 PM   #28
Old 28th February 2011, 10:45 PM   #29
Default SE Amp Brochure
Did not mean to sidetrack the thread with the loudspeaker information. A new thread will be started for that when ready.
Here is a brochure for the amplifier with details all on a one page PDF.
Old 2nd March 2011, 07:37 PM   #30
REDHORSEMAN's Avatar
Hi Bob,
Scott
yea I would be intrested in floor standers
let me know
Bob
KT88 SE Complete Kit scott17 Tubes / Valves 289 4th March 2013 08:09 PM
AnalogMetric 6L6GC SE amp kit...thoughts about this kit? jmillerdoc Tubes / Valves 2 16th November 2009 02:51 PM
Kt88 Se overdrajv Tubes / Valves 0 16th December 2008 12:26 PM
My KT88 SE project JesseG Tubes / Valves 8 20th April 2008 04:26 AM
Kt88 Se hacknet Tubes / Valves 9 10th September 2004 08:19 AM
Copyright 1999-2017 diyAudio
