| Vendor's Bazaar Commercial Vendors large & small hawking their wares |
#191 |
All of the kits have been sold.
Thanks to all. Scott |
#192 |
No . . . THANK YOU!!!
I'm glad I got mine when I did. You did a great job on the design and the kit came with excellent instructions. The idea of a "first time amp build" was a bit overwhelming at first thought, but the instruction details in this kit were very good. I completed mine a little over a year ago, and have to say that the sound is superb. The only problem I've had is that it's been in storage for the past few months, while the "man cave" has been under construction! I'm looking forward to getting it hooked up again in the new digs. ![]() ~Dave
- Dave R the 200% Norske |
#193 | |
Best Regards, TerryO
"If you have to ask why, then you're probably on the right track." quote from Terry Olson's DIYaudio Forum application |
#194 |
Hi Scott,
I'd really wanted to try out your Design of this Amp. But the shipping costs to Europe (incl. the transformers) are ridiculous. Sorry! Are there more Europeans out there that want to build the same Design? May be we can find find an extra solution? I really would like to test it! Ciao Christoph |
#195 |
It should not be that difficult to source the parts locally. As you know, the parts list is in the very first post of this thread as well as the transformer specifications.
Here is the link to the schematic and chassis layout: KT88 SE Complete Kit See post #126 There are several photos of the interior layout in this thread. The layout and grounding scheme is important. It is also important to use the individual LC filters for the driver tube. I'll be glad to help in any way I can. Scott |
#196 |
I haven't even built mine yet but I'm already excited and hankering, got the 'covets' for a 2 x SE KT88 mono block. Hint hint. Should probably finish this one first. Maybe in a year from now. My build will be slow. This will be my first valve amp. What kinds of speakers are people using? Dave R looks like he has some DIY 2.5 way? How does it go Dave?
#197 |
The TMM in my set up is not a 2.5 way. The (2) 6.5 midwoofers are 4-ohm, wired together in series for a (nominal) 8-ohm load. The crossover from woofer branch to tweeter is a series. I would consider it a 2-way. These are tuned to ~ 41 Hz.
The TMM's are very nice sounding (IMHO of course I have a smaller 2-way bookshelf pair (also vented, and also series crossover) which is a magical match with this amp. It is tuned to ~ 64 Hz, but even without a sub I find it quite enjoyable. One day, I'll re-build the cabinets on these to match the amp case.
#198 | ||
Dear Scott,
That was the purpose of my post: Did anybody in Europe find any good source for the heavy stuff? Quote:
Buy your chassis/Kit,witch i really lik, but without the heavy stuff. Find some people around here to get a small series made of the coils. Ciao Christoph |
#199 |
Hi Christoph,
I certainly didn't mean for my response to be taken in a negative way if it was. I really am glad to help in any way that I can. All the best, Scott |
#200 | |
Just a note: unlike some of the popular wisdom that unfortunately passes for truth, it's certainly possible to have better bass from tubes, if the speakers are correctly designed with that in mind. Best Regards, TerryO
| KT88 SE Complete Kit | scott17 | Tubes / Valves | 289 | 4th March 2013 08:09 PM |
| AnalogMetric 6L6GC SE amp kit...thoughts about this kit? | jmillerdoc | Tubes / Valves | 2 | 16th November 2009 02:51 PM |
| Kt88 Se | overdrajv | Tubes / Valves | 0 | 16th December 2008 12:26 PM |
| My KT88 SE project | JesseG | Tubes / Valves | 8 | 20th April 2008 04:26 AM |
| Kt88 Se | hacknet | Tubes / Valves | 9 | 10th September 2004 08:19 AM |
