KT88 SE Basic or Master Kit - Page 10 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 19th February 2012, 05:06 PM   #91
iNSuL is offline iNSuL  United States
Original bias was closer to 4 volts, so two 2v leds would be better. I started out with those exact ones and moved up to the 2 volts.
Jonathan
Old 19th February 2012, 05:10 PM   #92
debk is offline debk  United States
debk's Avatar
What was the difference in the sound using the 2V LED's ?
Debra
Old 19th February 2012, 05:34 PM   #93
To me it made it a little colder, more sterile sounding. Highs seemed a bit more harsh. Not by much though, both still sound really detailed.
Jonathan
Old 19th February 2012, 05:42 PM   #94
debk's Avatar
I just ordered a few different LEDs. I will have to experiment with it.
Thanks for the information
Debra
Old 19th February 2012, 07:28 PM   #95
regiregi22's Avatar
Try combinations of different LED colors, as each one will have a different voltage drop.
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN!
Old 19th February 2012, 08:50 PM   #96
debk's Avatar
Just trying to see if I understand this correctly.
If I were to bias the 6n1p with two HLMP-6000, the new bias voltage would be about 3.2V. This would give a slightly higher Plate current. In the original design the current is 4mA, an easy point to read off the curves. Changing to the 3.2mA bias the current would increase to around 5mA if I extrapolated the curves correctly (eyeballing on the computer screen). Would you have to decrease the Plate resistor to keep the plate voltage constant and keep you out of a nonlinear part of the curve. If the 3.2V bias truly gives around a 5mA bias current than the by my calculations the plate resistor should be dropped to around 39K to put you on a linear part of the curve.
I may be way off here, but trying to understand how the circuit works.
Debra
Old 19th February 2012, 09:48 PM   #97
Debra
That looks to be about right. I've read that when biasing with LEDs, a little more current, say around 10mA, helps with the linearity. With this circuit, the current through the 6N1P could be increased to 6mA by paralleling a 68K 2W resistor with the existing 47K. That would be an effective 28K (about), and would also maintain the -4V bias point. At 6mA, if you wanted to go back to a resistor/cap for the bias, the new value is 680R 1/2W.
Old 20th February 2012, 04:16 PM   #98
regiregi22's Avatar
Just out of curiosity, is it possible to get the part numbers of the MP oil capacitors?
ASC Capacitors - Products
Old 20th February 2012, 07:11 PM   #99
The capacitors are Panasonic:
DS371506-CA
DS371306-CA
Old 22nd February 2012, 01:22 AM   #100
debk's Avatar
One more LED bias question. I have done some reading on this circuit. Some are advocating biasing the 6N1P at around 3.2V or so (two 1.6V red LEDs) , instead of the 4V the specified resistor will give you. This bias point should run the tube at a slightly higher current. If you were to do this does the 47K plate load resistor need to be tweaked?
Also has anyone tried replacing the plate load resistor with a constant current source?
Debra
KT88 SE Complete Kit scott17 Tubes / Valves 289 4th March 2013 08:09 PM
AnalogMetric 6L6GC SE amp kit...thoughts about this kit? jmillerdoc Tubes / Valves 2 16th November 2009 02:51 PM
Kt88 Se overdrajv Tubes / Valves 0 16th December 2008 12:26 PM
My KT88 SE project JesseG Tubes / Valves 8 20th April 2008 04:26 AM
Kt88 Se hacknet Tubes / Valves 9 10th September 2004 08:19 AM
Copyright 1999-2017 diyAudio
