IRS2092 (IRAUDAMP7S) + IRFI4019 - Page 6 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 2nd February 2011, 11:46 AM   #51
Originally Posted by luka View Post
What?? I hope you didn't use P channel!!!
This is HI side driver also, that this means is, that it driver ONLY N channel fets, which are far better then P.
No i used N channel for both.. i was just wondering
Old 2nd February 2011, 11:49 AM   #52
luka is offline luka  Slovenia
luka's Avatar
Send a message via Skype™ to luka
Originally Posted by Boudemaniak View Post
Ah, i see now that internally a 6V zener is connected to VAA and VSS so the 2.7k resistor is the dropper resistor..
Right, but I like to use external, since those are now for any sort of protection only
home page @ http://www.classdaudio.tk/ @ 24/7 all year long
I FEEL SLOVENIA
Old 2nd February 2011, 12:54 PM   #53
Some extra information:
Both fets are open. So if i remove 1 fet, there is no problem. Even the chip will only drain about 10mA.
When both of them are installed i have a big short and the chip will drain 300mA. It can't be the fets since i placed in new ones. This must be a chip problem, but what?
What drives the chip to open them both? I hope someone ever had the same problem
Old 2nd February 2011, 01:06 PM   #54
luka's Avatar
unless IC is damaged, it can't open both at the same time, it has circuit to prevent this... but what is has it dead time, which I would set for now to max
I FEEL SLOVENIA
Old 2nd February 2011, 02:00 PM   #55
That's what i thought! But i already replaced the IC so this shouldn't be the case.
Measuring between pin 9 and 10 is about 9V, so according to the table this is way too high for even the DT1 (25ns).
Im gonna make the dead time max, then i'll report back
Update: still nothing, but this is probably because the low side fet is still missing. Im still afraid though that it will give a short again!
Update2: Indeed it does :P
Old 2nd February 2011, 03:02 PM   #56
Hmm, seems like the chip keeps blowing the fets! This shouldn't happence since i recently put in a new chip. When i measure over pin 15 and 13 without the fets, i have no voltage. Even only pin 15 to gnd is 0V, but the resistor is placed correctly. Must be the chip i guess?
Old 2nd February 2011, 04:15 PM   #57
luka's Avatar
yes 9v means you are on lowest DT setting. You need both fets in the circuit! maybe your freq is set too high, that would bring consumption way high
what are you resistors and caps for freq setting?
And as long as you have some resistors in series with power lines, there won't be any problems
I FEEL SLOVENIA
Old 2nd February 2011, 04:17 PM   #58
luka's Avatar
without fets you won't be able to measure the voltages, since they are a must for circuit to work
Capacitor between 13 and 15 will charge only when lower fet open
I FEEL SLOVENIA
Old 2nd February 2011, 08:01 PM   #59
I looked it over and i cant find any reference on how to set the oscillator. It's standard 800kHz.
Theze are my values:
I know i need the fets, but when i put in a working fet (no matter what side) it will blow. Then i remove it and measure it, it has a short between drain and source. I've blown about 5 fets now hehe
SO the high side driver isn't broken either, so what is? Something must be wrong? I only have 1 new IRS2092 left so i must be careful
Im getting dizzy, time to get some sleep i guess
Old 2nd February 2011, 08:14 PM   #60
luka's Avatar
you really need this PDF, other one is totaly useless
http://www.irf.com/technical-info/appnotes/an-1138.pdf
here you will find some values... I have found that because I have such fets and all, I have diffrent values, so expect to have diffrent freq., so don't go crazy with values
You set is by resistor an 2 capacitors
What fets are you using?
maybe you should remove those big capacitors for now, since those provide the current to do that
show me schematic that you have now, I won't check the pcb if everything is connected where it should be though
I FEEL SLOVENIA
Irs2092 luka Class D 50 15th July 2012 01:48 PM
IRS2092 AMP help yaronshani Class D 3 29th January 2010 02:29 PM
Irs2092 gxhcdba Class D 11 14th December 2009 10:54 AM
IRS2092 help! yudi02 Class D 2 11th October 2009 03:30 AM
Copyright 1999-2017 diyAudio
