LJM Audio
AC TO DC
MUR8100E * 4
63 V2200UF * 8
For reference.
:D
56W or 56V.. if it's 56 Watts.. it won't do the job for either. I'm looking at 300 - 500 Watt SMPS for use with the L15D
If it's 56V, then the L15D is the choice, 55V is the recommended voltage in a 45-60v range
The L20D has a range of 60-80 with a recommended of 70V
ljm_ljm
Do you have a PSRR measurment for the L15D? I'm thinking about using a SMPS Power supply from Connexelectronics like the SMPS500QR..
You are going to use a switch power supply, switching power supply I used in the L15D, and L15DX2 above
(IRAUDAMP7S-150).
They are all very good work, and my client installed in the L15D car above. Use a
DC12 > +-50 V switching power supply.
As long as you change the voltage of power supply is less than 10 V +-basically do not have too big effect.
