Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 31st January 2011, 11:57 AM   #31
dudaindc's Avatar
Originally Posted by Cristi View Post
Single channel, IRS2092S driven class D amp, output power up to 600W (with other MOS-FET's and caps) the shown one has 300W. the main application is multi-channel amplifiers. it only requires the main differential supply voltage, and has some ingenious power management scheme to save power as much as possible. Dead-time is set to min. 25ns, and the pk-pk overshoot is about 2V only, due to the tight layout.
I've made them for a friend who integrates them in some amps which he build. Soon i will have a batch for sale on my site too.
Nice!!!
Rubycon || Nichicon
Old 1st February 2011, 10:49 AM   #32
ljm_ljm is offline ljm_ljm  China
Originally Posted by moschfet View Post
hi people,
I have build a prototyp with irs2092 and irfb4212. Two things struck me.
-the amplifier have a strong noise, I can it hear till 50cm from the box.
-the amplifier disturb the the radio(HF-radiation).
Do you have similar experiences?
AMP in the use of noise in this very small, I took him to work in 680K HZ.
Using shielded filter inductance. 22UH, will be about +-40V 680K square wave signal filtering is very thorough.
The remaining approximately 200MV + - 680K HZ sine wave.
Most of the noise because the ground is because the PCB LAYOUT interference caused
Please refer to IR IRAUDAMP7S PCB LAYOUT.
I also have IR official template design products. In use, did not hear a difference.
Thanks everyone
Old 1st February 2011, 08:27 PM   #33
nigelwright7557's Avatar
Thanks everyone
I had a problem with my first 2092 pcb.
I tracked it down to noise on the VCC line.
I fixed it with a 47uf right next to the 12 volt regulator.
http://www.murtonpikesystems.co.uk PCBCAD50 pcb design software.
Old 1st February 2011, 09:07 PM   #34
I have a question about that. My circuit isn't really functioning well.
I followed the application diagram except i added some decoupling. A BIG capacitor over the drain and source of both fet's, a BIG capacitor over the B+ and B- and a pretty big one from my VCC to B-.
For the VCC i used a 7812 with input +B, reference (gnd) -B and output the VCC line. I found this in the IRAUDAMP document, but that means it has a voltage drop of 40V or something? Isn't that way too high?
THen my last question: Is it possible to test it without connecting the low pass filter and speaker? I want to measure it first before adding a big load..
Old 1st February 2011, 09:14 PM   #35
I use a 200ohm dropper resistor from 45 volts to the regulator.
You will need to decouple the regulator on the input and output as close to the regulator as possible
I was getting something like a 1KHz tone when the regulator wasnt decoupled properly.
I was also getting quite a bit of background noise until I earthed the input ground.
Old 2nd February 2011, 03:54 AM   #36
luka is offline luka  Slovenia
luka's Avatar
Send a message via Skype™ to luka
Boudemaniak, show the pcb
home page @ http://www.classdaudio.tk/ @ 24/7 all year long
I FEEL SLOVENIA
Old 2nd February 2011, 07:23 AM   #37
I am still unsure about 2 things.
1. Isn't it working because i did add the load?
2. Are my decouple capacitors placed correctly? (1 over each fet from drain to source.. shouldn't it be drain to ground?)
Old 2nd February 2011, 07:44 AM   #38
luka's Avatar
1.well load is part of the output filter, so yes you should have it connected (even if few times higher then intended)
2. capacitor from v+ to gnd, and from gnd to v-
Power tracks are narrow, probably too long also, only single gnd (you could find my amp or look for 2092 app note how grounds should be placed)
I FEEL SLOVENIA
Old 2nd February 2011, 07:49 AM   #39
But the feedback is placed before the low pass filter. I thought this shouldnt be a problem.. But ok, i'll add the LPF and a power resistor.
And capacitors should not be placed over the drain and source then? Man, what was i wrong I'll try it now
Old 2nd February 2011, 08:35 AM   #40
Well, did all of the above things and added a 100Ohm resistor as load. The current now is 200mA for V- and nothing for V+. It seems like the IC isn't driving the fet's (although we dont have a short now ).
Is the VCC correct? I used a Lab-supply with the - connected to the V- and +12V connected to the VCC. This means that it's -8V (with +-20V supply) with respect to ground.
Any ideas?
Ps: CSD Isn't resetting, so that's a good thing
Irs2092 luka Class D 50 15th July 2012 01:48 PM
IRS2092 AMP help yaronshani Class D 3 29th January 2010 02:29 PM
Irs2092 gxhcdba Class D 11 14th December 2009 10:54 AM
IRS2092 help! yudi02 Class D 2 11th October 2009 03:30 AM
Copyright ©1999-2013 diyAudio
