Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 9th March 2012, 03:11 PM   #161
ljm_ljm is offline ljm_ljm  China
Originally Posted by alkasar View Post
Happy new (chinese) Year ljm
Laugh.
Is done and leave for some time. The work is very busy, as well as there is no time to DIY and to forums.
Was too busy
Old 9th March 2012, 07:49 PM   #162
So is there anyway to BRIDGE two of these modules? and what would the power rating be?
Old 9th March 2012, 08:59 PM   #163
Just forget the last post.. postet it in the wrong forum, was supposed to be in the L25D
Old 18th March 2012, 09:25 PM   #164
Idefixes's Avatar
Send a message via ICQ to Idefixes
hi ljm,
Could you give the heatsink thermal resistance carateristics that you involve in L15D ver.3?
Marc
website : http://audiyofield.wifeo.com/index.php
Old 19th March 2012, 10:18 PM   #165
soren5 is offline soren5  Denmark
Default L15D for active 2-way?
I’ve been lurking this and the L20D thread for some time and have a few questions about the boards. I’m building an active 2-way bookshelf speaker with a full range driver and a bass woofer where I plan to use the 2 x L15D boards + 1 x SMPS inside each speaker. The full range driver is 8 ohm 20W and the is woofer 4 ohm 150/300W (nominal/peak). For power supply I’m planning to use the SMPS300RE +-45V.
  1. Will the speaker drivers’ impedance difference be a problem for the L15D boards + SMPS300RE?
  2. Although the SMPS300RE is not taking advantage of the L15D’s full potential (as opposed to e.g. the SMPS500R), will this SMPS be sufficient considering the speaker drivers I’m using?
  3. Is the heat generated from the boards so high that I need to vent the speaker enclosure or even place external heat sinks?
Thanks for the advice.
Old 27th March 2012, 11:49 AM   #166
It should use the L15D + - 45V DC power supply.
The L15D the fever is lower than the L20D 25D. He can be full of power without the need to increase the radiator.
Old 27th March 2012, 11:53 AM   #167
Recommended to use this.
Its circuit by IRAUDAMP7S.
It can achieve 500W power 8 OHM
Old 1st April 2012, 03:09 PM   #168
Originally Posted by noah katz View Post
ljm_ljm,
With the heat sink vertical on the board it doesn't look like convective airflow over the fins will be very good, since the board underneath blocks it.
Do you know what is the maximum average power that a module can dissipate when in a closed box?
And how much if the box has ventilation holes above the heat sink?
Also , what are the dimensions of the board? I searched but didn't find them, and the ebay vendors don't give them either.
Marked on the front of the reference map detailed size chart I can find.
L15D fever is relatively small in actual use, almost no temperature.
Old 18th April 2012, 10:15 AM   #169
According to the datasheet of the original IRAUDAMP7s has multiple protection features that have not been included in LJM designs.
  • Over-current protection (OCP),
  • high side and low side MOSFET
  • Over-voltage protection (OVP),
  • Under-voltage protection (UVP),
  • DC-protection (DCP),
  • Over-temperature protection (OTP)
Anyone know if its necessary in original (or ebay copy ) IRAUDAMP7s amp add another protection circuit as a delay for anti-plop or similar?
Old 18th April 2012, 10:24 AM   #170
alkasar is offline alkasar  France
Cristi's latest IRS2092 designs are supposed to include multiple protections.
Connexelectronic CxD400
Connexelectronic CxD300
The detailed description is not yet on the website.
Speaker protection board, including anti-pop delay are easy to find on ebay.
Irs2092 luka Class D 50 15th July 2012 01:48 PM
IRS2092 AMP help yaronshani Class D 3 29th January 2010 02:29 PM
Irs2092 gxhcdba Class D 11 14th December 2009 10:54 AM
IRS2092 help! yudi02 Class D 2 11th October 2009 03:30 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
