| Vendor's Bazaar Commercial Vendors large & small hawking their wares |
#151 |
Is the A350SMPS from connexelectronic (350W) suitable for LJM's L15D board? I'm trying to decide whether or not I can save the $30 over the SMPS500R. I'll only be using one channel.
#152 |
I would say it is
#153 |
I would give preference to a regulated SMPS. 300R, 500R is a matter of power needed.
#154 |
#155 | |
Un-regulated power supply output voltage may vary, according to the current required by the load. ClassD amplifiers have a relative lower PSRR (power supply rejection ratio) than traditional classA or AB amplifiers. They behave better with a regulated power supply. |
#156 | |
or if you want some Bedtime Reading... |
#157 |
I bought a pair of L15D on ebay. I tried to power the boards as per the daigram on the sellers site. I used a meanwell SMPS at 55 vdc and the amps did not power up. I tied to PM ljm but his in box is full. Can anyone help. Best Regards, elb |
#158 | |
I have L15D - it needs a slit rail supply with +/- rail and ground. Meanwell SMPS supplies only single rail only - are you using two Menawell supplies for +/- 55V DC? |
#159 | |
If you have two identical single-voltage, and their ground and did not turn, you can get dual-voltage series. Be careful on the power supply.
#160 |
Happy new (chinese) Year ljm
| Irs2092 | luka | Class D | 50 | 15th July 2012 01:48 PM |
| IRS2092 AMP help | yaronshani | Class D | 3 | 29th January 2010 02:29 PM |
| Irs2092 | gxhcdba | Class D | 11 | 14th December 2009 10:54 AM |
| IRS2092 help! | yudi02 | Class D | 2 | 11th October 2009 03:30 AM |
