Warpspeed -An Optocoupler Volume Control - Page 3 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 3rd December 2010, 02:32 PM   #21
Blues is offline Blues  United States
Blues's Avatar
Originally Posted by ondesx View Post
People who believe in their ears in defiance of the measurement are the same that those who prefer the religion to faith!
OndesX
If it's music reproduction, I'd rather believe what I can hear...am I going to force myself not to believe because the numbers say so? First I'll probably say, "It can't be!" but I'll probably conclude, "...but I like it!" -which is what matters in our hobby, not religion or faith.
Life simplified! Leap into the Warpspeed wormhole... http://www.6moons.com/audioreviews/warpspeed/1.html
Old 3rd December 2010, 02:33 PM   #22
Blues's Avatar
Originally Posted by moray james View Post
you have a pm. regards Moray James.
Got it Moray...will reply in a bit.
Old 3rd December 2010, 02:39 PM   #23
Blues's Avatar
Originally Posted by analog_sa View Post
10k output impedance just doesn't seem possible
This is from 2 different Sony players from different eras. One is an SACD/CD and the other a Blu-ray...I'd think typos would have been corrected between the two.
Old 3rd December 2010, 03:12 PM   #24
qusp is offline qusp  Australia
qusp's Avatar
measurements cannot be disregarded though, subjective assessment is VERY important, but not 100% reliable
Old 3rd December 2010, 03:35 PM   #25
Blues's Avatar
Originally Posted by qusp View Post
measurements cannot be disregarded though...
Of course...measuring for safe operation is the most important.
Old 3rd December 2010, 06:20 PM   #26
qusp's Avatar
hehe touche, well I think i'm just going to watch from the sidelines for a while, the other thread is getting rather heated up and I must say any critique of this device by zealots does tend to bring on the battle from all corners. it may not be palatable to me for my current usage, but I respect others right to their own taste or motivations in this hobby.
The fact is it measures badly, that is a fact, there are simpler ways of adding pleasing 2nd harmonic distortion in less strange places than at an input where you cannot turn it off, but we all know that is not the whole story. how much of the story it is for any one person is a matter of taste and I cannot argue with that.
I have mostly built up the boards I have had here for some time just recently, but I do not know when I will get a chance to listen to it, my system and everything in it is balanced and this presents some problems, as does the output and inputZ, but that will not stop me trying it out, I have heard it in a friends system, but only with tubes, which are not really my taste so this probably wasnt a fair test.
try and keep it a clean fight chaps
Old 3rd December 2010, 08:13 PM   #27
georgehifi's Avatar
Send a message via MSN to georgehifi
cheers:
"measures badly" I would not consider .01% 2nd harmonic a bad measurment, at full level 0dbu from a cdp which they never reach on normal cd's it's still only .1%.
Then consider the lack of distortion "diode rectifcation effect" a pots wiper contact gives which can't be measured, this is why so many say the Lightspeed is the cleanest full bodied sound they have heard. Trust your ears as well as the analysing equiptment.
Cheers George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 4th December 2010, 08:01 AM   #28
Blues's Avatar
Going back to these postings by Mr. Pass Lightspeed Attenuator a new passive preamp and the attached %THD vs V curves...if you look at it, most systems would operate in that valley region up to 0.5V.
With an amp with a gain of 10 this would already be 5V at the loudspeakers very loud even for moderate speaker sensitivity. Voltage peaks this high will only be instantaneous hard drum whacks very short in duration so it's not like you are listening to a continuous 0.025% distortion like if it were a sine wave fed into the amp. An F5 at gain of only 5 will also be already loud.
Correct me if I'm wrong Mr. Pass, your test set-up was the 600R source with a shunt LDR? Will there be an improvement with series-shunt LDRs' distortion cancellation especially at series LDR = shunt LDR values?
Old 4th December 2010, 10:14 AM   #29
analog_sa's Avatar
I'd think common sense should prevail. Or maybe not.
Old 4th December 2010, 10:19 AM   #30
analog_sa's Avatar
So,to put it simply: high measurable distortion but low immeasurable
Volume control on DVD player remote. Lose resolution at low volume? Circlotron Digital Source 2 10th June 2011 07:20 PM
CDM-4/19 running at warpspeed Pharao.Pharao Digital Source 13 5th May 2008 12:43 PM
i need preamp schematics w/o tone control or volume control hernanstafe Parts 7 30th January 2008 03:12 AM
The remote control paratactic volume control audio-gd Solid State 33 7th June 2007 11:16 PM
remote control motorised control for volume pot/knob CharlesY Parts 0 25th July 2005 11:12 AM
Copyright ©1999-2017 diyAudio
