Warpspeed -An Optocoupler Volume Control - Page 21 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 28th April 2012, 01:55 AM   #201
Blues is offline Blues  United States
Blues's Avatar
Default V24.6ch
Here's the final front/rear panel layout...push the button for stereo cruisin'!
Life simplified! Leap into the Warpspeed wormhole... http://www.6moons.com/audioreviews/warpspeed/1.html
Old 29th April 2012, 09:13 PM   #202
Blues's Avatar
Default 14 Trillion eVolts!
New subatomic particle found at super-collider - Technology & science - Science - msnbc.com
Old 1st May 2012, 12:42 AM   #203
Blues's Avatar
Default And now the Pudding...
...fresh from the oven.
Old 7th May 2012, 05:00 AM   #204
The WarpSpeed 6 channel in operation.. Currently a 3.1 setup ( no rears ). I am using the AudioPraise Vanity93 to generate the 6 Channel Coax to replace the lack of HDMI. The Octave dac provides L + R and the Bifrost dac generates the C + LFE. To be honest , U would be hard pressed to build a better HT setup.... I also own a Classe SSP-800. The WarpSpeed 6ch preamp is a game changer.
Dwight
Old 8th May 2012, 12:09 AM   #205
Blues's Avatar
Thanks for the update, Dwight! It looks like the V24.6ch found a good home and great buddies to play with...It's just incredible getting compared to an $8k HT processor!
The Warpspeed doesn't have all the bells and whistles but offers to simplify your already complicated life of gizmos, pushbuttons, and mind-numbing menu selections.
Attached is happyrabbit's HT system as he envisioned it once he has all the pieces...
I hope you will have endless hours of enjoyment both in stereo and HT!
File Type: pdf Multi-Ch Warpspeed V24 Applications -pp3.pdf (140.8 KB, 63 views)
Old 12th May 2012, 04:49 AM   #206
Blues's Avatar
Pics showing in stereo "green" cruise-control mode, and in full 6-ch "afterburner orange" mode...
Old 21st May 2012, 11:49 PM   #207
Blues's Avatar
Squid ink from Jurassic period identical to modern squid ink, study shows
Old 29th May 2012, 12:08 AM   #208
Blues's Avatar
Default V12
With the V24 serving the active bi/tri-amping crowd, the V12 circuit has been updated to bring it in line with the transWarp (xW) design as part of the evolution of the Warpspeed. It was first introduced here... Warpspeed -An Optocoupler Volume Control
The V12's application is for passive bi-amping. It utilizes loudspeakers with 2 pairs of speaker terminals whose internal high/mid and low crossover networks can be made independent by removing external jumpers linking the binding posts. Passive bi-amping has the advantage, over active, of enjoying what you paid for when you bought your speakers...the competence of the designer. Having all the parts tuned to work as a whole. Also, less fuss of measuring, tuning, adjusting, including additional expenses on active crossovers, and test equipment...which I believe is best left to speaker designers and experienced diyers.
As can be seen on the V12's internal pictures with 3 'Squids, the new design will now just run off a single 'Squid. There are 2 versions of the design...separate left and right level controls adjusts highs/mids and lows against each other -that is, CW turn brings up the highs/mids and CCW the lows. Or independently controlled highs/mids and lows each for the left and the right channels. It also sports a balance control to have the ability to finely adjust L-R balance as needed. The main volume control adjusts stereo levels while maintaining relative as-tuned levels of highs/mids and lows.
Attached is an illustration of passive bi-amping...
Old 30th May 2012, 04:42 AM   #209
Blues's Avatar
Default Recommended!
Two Men with the Blues - Wikipedia, the free encyclopedia
Old 11th June 2012, 01:57 AM   #210
Blues's Avatar
Default Chopin -Vladimir Ashkenazy
Beautiful music, well recorded piano...
Amazon.com: Chopin: Favorite Piano Works: Frederic Chopin, Vladimir Ashkenazy: Music
Volume control on DVD player remote. Lose resolution at low volume? Circlotron Digital Source 2 10th June 2011 07:20 PM
CDM-4/19 running at warpspeed Pharao.Pharao Digital Source 13 5th May 2008 12:43 PM
i need preamp schematics w/o tone control or volume control hernanstafe Parts 7 30th January 2008 03:12 AM
The remote control paratactic volume control audio-gd Solid State 33 7th June 2007 11:16 PM
remote control motorised control for volume pot/knob CharlesY Parts 0 25th July 2005 11:12 AM
Copyright ©1999-2017 diyAudio
