Warpspeed -An Optocoupler Volume Control - Page 11 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 11th May 2011, 03:44 PM   #101
Blues is offline Blues  United States
Blues's Avatar
Here's some findings from a kit builder...James, you're welcome to pop-in and add to it...Thanks!
"Played some tracks "Daves True Story" for balance, DiMeola, McLaughlin, etc (Sat Night ...) for detail, Olatunji "Babatunde" for Bass, Red Priest version of Vivaldi "4 seasons - track 1 - Spring" for the speaker resonance check and natural instrument sound, Enya "Amarantine" for resolution on multitrack overdubb (difficult for the old phillips 1541A dac players), Mahler Symphony No 2 (Budapest Orchestra with Ivan Fischer) [ I'm not a big classic person and especially Mahler but this selection stayed the whole 27 minutes!]
Suffered thru that ghastly Alison Krauss "Forget About It" AudioPhool remastered crap (maybe okay on MP3 players, or something!!) and just changed to Peggy Lee "Fever" - rather good recording from some years ago....
Added an Elna 1000uF/25V cap across the battery and improvement in clarity but initially unbalanced the sound a lot, with lack of bass but after about 30 minutes now, the balance has come back and the improved clarity extends to the bass as well - I'll leave the cap there for a week and then try it without, to check if it's just my imagination or not - has happened before a few times!
[After dinner change, not the week! - just out of curiosity, replaced the 1000uF Silmic with a 4700uF Elna for Audio (Starget) cap and more bass at the start - how interesting ....]
Now, in comparison to the sound of the PassLabs X2.5 preamp, the sound is considerably cleaned, more open, more detailed and without any of the usual fatigue that normally accompanies this - the only problem is the lack of gain on some of the quieter tracks so I'll just increase the CD o/p to about 3volts that should take care of things.
Looks like the poor old Pass X2.5 is in need of the external shunt reg power supplies, plus a heart transplant! - the difference is pretty obvious.
Playing music at low levels doesn't seem to "thin the sound down" as you have found, and I can confirm that the same thing is apparent here as well.
I wonder if I can get this same "sound" of your Warpspeed (W/S) from the Cavalli valve buffer (Heretical III) for the "gain stages" of the electronic Xover - I do need the buffers between the filter stages and can fit the W/S to the Xover main vol control - hmmm ...
Perhaps the most noticeable difference to the Passlabs preamp is heard on my AKG k170 headphones via Patrick's (EUVL) DAO follower amp - I use this as my reference and the sound of the F3 amp, the Coral beta8 Full Rangers (150Hz+) & Lorrantz 12" bass drivers (150Hz-) are setup to approach this sort of sound - a bit of a cross between monitors and hifi speakers, in my reasonable acoustic room, a bit bass shy.
So, you have designed and built a winner here, no doubt about it - I'll get my Uriah's built up kit back next weekend and see what differences there is between them."
Life simplified! Leap into the Warpspeed wormhole... http://www.6moons.com/audioreviews/warpspeed/1.html
Old 12th May 2011, 05:41 AM   #102
Blues's Avatar
Other notes from James...
"It'll be interesting to see what happens as I get used to it - annoying the others a bit this late at night with the much higher volume that it seems available without seeming to be LOUD - and I do like that bass clarity - even "Buddha's Party's" now listenable!
...and will plod on to finish the F5 amps and get started with the Xover - I got a few extra pcbs for the symetrical B1 to use for that B1 Xover but, after the contrast of the W/Speed to the X2.5 preamp that uses similar buffers, not so sure now and will have a bit of a rethink..."
Old 13th May 2011, 03:02 PM   #103
I don't want to give the impression that the PassLabs X2.5 Preamp is a low quality product - it's not, in any system - it does function better as a balanced preamp and does everything you can expect from an item from PassLabs, even this the entry model.
I've had it for a couple years now and it's been mated up to quite a few different amps/sources and never a mis-match - quite surprising, really.
Allan's "Warpspeed" is a Passive Vol Control and a rather well designed item indeed - it has remarkable clarity and detail and suits the F3 perfectly, not an easy thing to do - even Uriah's variable LighterNote design needed the buffer.
I'm playing with the capacitors across the Leds now, and battery supply variations later - it'll be interesting .....
Old 13th May 2011, 06:27 PM   #104
Blues's Avatar
I appreciate you chiming in, James. No doubt that cleared up the air for us Pass fans. I'm just happy getting it compared to a quality product and able to hold its own.
Is it then safe to add another advantage over other LDR designs -on the Warpspeed's ability to nicely partner with low input impedance amps without the need for a buffer? The F3 being about 9k?
I've held back on declaring it outright until someone actually says so with actual use. I was shooting for this advantage during the design process. Theoretically it will probably work down to a low 4k of amp input impedance and probably paired with 3Vpk or more of Source voltage output...so DACs with this higher than standard output will really help.
"Straight, No Chaser!" I think will be a nice signature...
Old 15th May 2011, 05:18 PM   #105
Blues's Avatar
Default WarpSquid!
Squid go into space – for the sake of humanity - space - 13 May 2011 - New Scientist
Old 17th May 2011, 06:36 AM   #106
Blues's Avatar
Default Just a bookmark...
Related discussions going on here...Lightspeed Attenuator a new passive preamp
Old 25th May 2011, 10:11 PM   #107
Blues's Avatar
I think I'll just leave them to their own devices...this Warpspeed thingy is too sci-fi!
Old 7th June 2011, 01:05 AM   #108
Blues's Avatar
Default Have Warpspeed, Will TravelÖ
Over the weekend I gutted my earlier diy version of the Lightspeed, re-used its box and wired up a Warpspeed. I built this with the hope of letting it loose for DIYAudio members who would like to give it a listen in the comfort of their couchís sweet spot. Itís open to members residing in the lower 48 states of the USA.
The idea is to ship it to the first member who expresses interest, with the agreement to have it to hopefully enjoy for 10 days and then ship it to the next member on the list. And it goes on as long as the list grows. Iíll cover the initial USPS Insured Priority Mail Medium Flat Rate Box shipping cost with Delivery Confirmation for tracking. Please keep this as our shipping standard (Total of $14.50 including $200 Insurance).
The picture shows the unit with 4x in-parallel 9V battery supply which I will include. Please replace when the voltage measures <5.0V or as needed. This Warpspeed is stereo Unbalanced with the middle RCA connectors as L/R INPUTs; the outer RCAs are OUTPUTs; it has a power switch to conserve battery power; and a DC power INPUT connector.
I take it as a given that the unit will be treated with love and care as it goes thru every stop of its 2011 US concert tour. Iíll ship it once we hit 5 members.
For interested parties the list starts now and here...
Old 7th June 2011, 01:07 AM   #109
Blues's Avatar
Also...I’d like to arrange for the unit to get to a member who will be visiting this October’s Burning Amp in the Bay Area and is willing to bring it along for anyone there who would like to give it a listen. Audiophile clubs are also welcome to list with month/week meeting info.
Old 9th June 2011, 02:49 AM   #110
Blues's Avatar
Okay, we have a couple of brave souls willing to try...please add to this list if interested.
1. nicksgem10s -MI
2. Tea-Bag -CT
Volume control on DVD player remote. Lose resolution at low volume? Circlotron Digital Source 2 10th June 2011 08:20 PM
CDM-4/19 running at warpspeed Pharao.Pharao Digital Source 13 5th May 2008 01:43 PM
i need preamp schematics w/o tone control or volume control hernanstafe Parts 7 30th January 2008 04:12 AM
The remote control paratactic volume control audio-gd Solid State 33 8th June 2007 12:16 AM
remote control motorised control for volume pot/knob CharlesY Parts 0 25th July 2005 12:12 PM
Copyright ©1999-2017 diyAudio
