Enjoythemusic review of jkeny modified Hiface - Page 2 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 10th January 2011, 04:17 AM   #11
Pano is online now Pano  United States
Pano's Avatar
Default Listening
Finally got a chance to lsiten to the modified hiface in action and compared to 2 other USB/SPDIF devices.
The Hiface sounds better.
I compared it to a cheap USB dac I got years ago off eBay. One of those 5.1 Dolby things with Toslink in and out - cost about $20.
Also compared to an M-Audio USB card that has coax SPDIF in and out.
The Hiface was "clearer." That's the best way I can describe it. More detail, more space, more ambiance, cleaner textures. It even sounds a bit more dynamic, but that has to be my imagination. Tonal balance is slightly cooler than the other adapters - maybe because the Hiface sounds more open, fuller.
On classical music it is the most obvious, from small string quartets to big choir with orchestra and pipe organ. On country and pop voices were more present and tactile. Cymbals more detailed, bass fuller.
I am not talking about huge differences here, not night and day. But maybe morning and mid afternoon. It is definitely more pleasant to listen to.
Important Caveats
  • This was not a blind test. I did the switching.
  • All listening done via headphones.
  • I have not heard the unmodified Hiface, so don't know if it's different.
  • The cheap adapter is optical only, which may make a difference.
  • I did not expect to hear a difference.
I do need to set up a blind test and will try to do so. I do believe that I can pick the hiface in a blind trail better than chance. But only the test will tell.
So far, that's what I've learned.
Take the Speaker Voltage Test!
Old 10th January 2011, 10:03 AM   #12
jkeny is offline jkeny  Ireland
Banned
Thanks Pano,
You have confirmed my & others scope shots above & the prediction that the attenuators reduce the perturbations by twice the value of the attenuation. This is predicated on the idea that it is reflections that are being reduced by this amount & reflections make a round trip i.e pass through the attenuator twice before reaching the DAC (or in this case the scope).
Nobody claimed the attenuators effected the bit-perfectedness of the SPDIF data stream. What they do effect (reduce) are these reflections. And as I have said before these reflections are directly related to the production of jitter effects at the DAC. I'm not the only one to claim this or that the attenuators work in this way.
I look forward to your scope shots & to your listening test results on the attenuators & the modified Hiface.
Old 10th January 2011, 10:27 AM   #13
Banned
Ah, I see we crossed posts.
Yes, thank you for this honest report. Your caveats are spot on & I look forward to your blind tests on both the attenuators & the modified Hiface.
Yes, a comparison against a stock Hiface would reveal the effects of my modifications & vindicate my lauding of battery power instead of USB power. I have stock Hiface units but shipping to US from Ireland & back is too costly. Maybe someone locally has one?
Old 10th January 2011, 04:36 PM   #14
Pano's Avatar
I'll try the attenuators, tho I don't think they will matter. Who knows, maybe that peaky waveform is what makes it sound good.
Old 10th January 2011, 04:48 PM   #15
Banned
Well, I believe the exact opposite - reducing/removing those reflections (peaky waveforms) will help the sound. Let's see who's right - maybe neither - maybe it will harm the sound . You should be good with about 20dB on the output of the Hiface. Try a smaller value on the output of your M-Audio. BTW, have you looked at it's SPDIF output waveform?
Old 11th January 2011, 01:50 AM   #16
Banned
A couple of other things, Pano, if I could ask of you:
-Can you use something other than a DCX as a DAC? Maybe some friends have a DAC?
- This thread is off the beaten track of the forum & I don't believe those that followed the RF attenuator thread will look at this so they will be denied the exposure to this new information.
-Could a post be put in the RF attenuators closed thread that points to this as the continuation of that thread. Would you be able to do this please? OR
- Do you want to reopen that thread with this new information or do you have any objection to me opening up another thread to put this in the main part of the forum?
Old 13th January 2011, 01:15 AM   #17
Banned
A bit of serendipity - a reviewer in Australia has just published this glowing review of the MK2 Hiface & the RF attenuators John Kenny modded M2Tech HiFace MK2
Old 13th January 2011, 01:42 AM   #18
sandyK is offline sandyK  Australia
John
Some friendly fire !
A nice review. However, who is this John Darko ?
What are his qualifications, and why nothing more than subjective reports ?
I have no problem accepting much of what he is saying, due to my own findings in this area, but his review fails to do more than confirm other subjective reports.
Alex
Old 13th January 2011, 02:13 AM   #19
Banned
Yes, Alex, you are correct, it is a purely subjective review with no attempt to measure or do blind tests. I guess it will be ignored by those who insist that a double blind test is the only yardstick by which they judge such subjective comments. This just adds to the weight of subjective evidence that has already been accumulated. However, I would also draw your attention to Pano's statement above
Of course, I hope that this doesn't negate the blind testing that he is intending as it does introduce an expectation bias. However, is it the case that an expectation bias only works on a blind test when the expectation is that no difference will be found?
Anyway, looking forward to Pano's further test results.
Pano, did you manage to get that scope shot ready for posting yet? It could be interesting.
Old 13th January 2011, 02:30 AM   #20
John
They would be much more meaningful if Michael is able to obtain a standard Hiface to do some comparisons against.I agree with your comments about a different type of DAC being desirable as part of the tests, but I applaud Michael's decision to use headphones, which are far more revealing of small differences in the absence of much higher resolution living room systems.
Alex
MK2 Modified Hiface jkeny Vendor's Bazaar 2 13th September 2010 01:27 AM
Modified Hiface now I2S to Sabre DAcs jkeny Digital Source 0 23rd April 2010 08:45 PM
enjoythemusic.com Holger Barske Everything Else 1 5th February 2004 02:04 AM
Copyright 1999-2017 diyAudio
