Another project, all digital DDX amplifier - Page 36 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 8th December 2012, 02:01 PM   #351
Send a message via ICQ to ackcheng
Does anyone uses the SMPS from hifimediy to power their DDX? Or is it better to use the linear power supply?
Old 13th December 2012, 06:56 AM   #352
raschaa is offline raschaa  Germany
I have the DDX hooked up to SMPS 300R, 38v turned down to 36v. No real listening yet, just hooked up "on the fly" for a quick test. Am working on the case right now.
Have noticed some "irregularities":
-dip switch on/off positions do not correlate with user manual table
- light hiss on free input channels, hooked up toslink input was dead quiet with source turned all the way down
- led-segments have different brightness
- no "." (dot) lighting on display during stand-by (completely dark)
only cosmetic issues, hoping the audio quality lets me accept them...
p.s. my first post^^ as a long time passive reader. Hi and thanks!
Old 19th December 2012, 09:20 AM   #353
All righty, got it up and running. First SQ impression is good, nice sound stage.
I do have one issue that I don't understand. I have a SBTouch connected via toslink to the DDX and it plays much quieter than my previously used Sure TA2024 via analog cinch. I have to set DDX at 0db and am still lacking quite a bit in subjective SPL in comparison. This strikes me as strange seeing that the DDX has a bit more power than a TA2024.
Ideas?
Old 20th December 2012, 04:22 PM   #354
soundcheck's Avatar
The voltage gain differs from amp to amp.
Usually you find values in the range of 20-30db. That can make up your difference.
A difference you could measure at the amp outputs or even with a simple SPL meter (see iPhone/Android apps). Best with a single tone.
But. There are more factors.
The more precise your chain gets the less grunge you'll experience. That grunge can make you think your system plays louder. A lot of people report
a rather "thin" listening experience with better equipment and turn their volume control further up.
But. It could aslo be the case that if you havn't done much tweaking to the DDX, your old amp could deliver a better "punch" (better dynamics) . This might sound louder on the first glance. Note: I'd give the DDX needs at least two weeks to settle.
A lot of of options. No clear answer. I know.
I think your question is not that easy to answer. Try the simple measurements first. Then read the datasheets. Usually you'll
find the base voltage gain listed.
Cheers
Old 20th December 2012, 04:30 PM   #355
soundcheck's Avatar
That what happens on rather poorly isolated SPDIF coaxes.
That's why I recommended to supply at least one SPDIF input with pulsetransformer.
However, even with a pulsetransformer in place you wouldn't wipe out all the junk.
Cheers
Old 20th December 2012, 06:25 PM   #356
Hey Klaus!
was kind of waiting for you to answer^^ Yes, my question is kind of "diffuse"...
I really should just let the amp "settle" as you commented. SQ wise I'm very impressed and it is already a good step beyond what I was listening to before. Miles Davis - Kind of Blue remaster was excellent as is J. McLaughlin - Live at Royal Albert Hall just rigt now. Alas I do listen to a lot of electronic stuff as well and that you can never hear to loud
Subjectively I could turn up the old amp until I started to hear the "grunge" and would then back off a bit. That was quite loud for 15cm single driver tqwt speakers. Now I can turn the SBT and DDX both to max and there is no Grunge and the speakers handle it fine except for maybe extreme electronic bass attacks. This leaves me thinking that there could/should be more SPL to be had??? But then again the 75w@8ohms of the DDX are not going to be so much more than the 10w the 2024 supposedly cranks out.... Sure-Elctronics website lists 27.6dB power gain for my old amp...
Wouldn't know how to measure at the outputs (Multimeter?), may just try a SPL app for grins.
Does your amp display have different brightnesses on the led segments?
Do you plan on documenting your DDX mods on your blog?
Danke schon mal
Ragnar
Old 21st December 2012, 08:50 AM   #357
soundcheck's Avatar
* I havn't really looked at the display brightness. I run it in auto-off mode
anyhow.
What I figured is that the timer seems to be much lower then 5s.
* I might consider to write something about the DDX320 V2 on my blog.
Cheers
Old 21st December 2012, 07:32 PM   #358
Nick gave me the heads up on the undocumented +10db feature of dip 4.... and yes those must be chinese seconds
By the way, have you done any "serious" attempts of using the sub feature?
Would really like to see one of your excellent write ups with the DDX as topic!
Old 24th December 2012, 02:25 AM   #359
i2k92 is offline i2k92  Indonesia
Anyone here compared the DDX with other HifimeDIY T1 & T2 amps ? I know that's not apple to apple comparison as they're all different beast. I just try to justify to buy the DDX or not as I have both T1 & T2.
Old 24th December 2012, 08:58 AM   #360
soundcheck's Avatar
Hi.
As a matter of fact, you need to compare your DAC+T1+cable/connectors+volumecontrol/preamp vs. DDX320.
It'll be not that easy to compare. However.
The class-d powerstages should have a pretty similar sound signature at least.
Anyone interested in a digital amplifier project? Rookie Class D 552 24th September 2014 08:29 PM
Apogee DDX EB-2060S 2x35W digital amp evaluation board ungie Swap Meet 5 20th May 2009 09:44 PM
Ddx-8001 cac liu Class D 2 9th July 2007 05:03 PM
Copyright 1999-2017 diyAudio
