| Vendor's Bazaar Commercial Vendors large & small hawking their wares |
My new Preamplifier
Introduction HPA-1 uses Dual FET input, Dual transistor and Class A transistor. It has one balance and one unbalance input. The 4 layers circuit board is sandwiched between two copper templates. External power supply is convenient to choose any kinds of power supply. Material Circuit board 4 Layers plating Transistor Linear Systems LS843 (Dual FET) Toshiba 2SA1349 (Dual transistor) Toshiba 2SC3381 (Dual transistor) Toshiba 2SA970 Toshiba 2SC2240 Toshiba 2SA1930 Toshiba 2SC5171 Resistance Vishay UXB 0207 0.1% 10ppm (Instrumentation) Vishay MMB 0207 0.1% 25ppm (Instrumentation) Vishay RN55D 1% 100ppm Precision Rssistive GP1/4 0.1% 50ppm Capacitor Philips 116 Aluminium electrolytic Nippon Chemi-Con Aluminium electrolytic Sanyo Aluminium electrolytic Wima MKP2 Evox Rifa MMK AVX Kyocera Ceramic Johanson Dielectrics Ceramic Integrated circuit Texas Instruments LM317 Texas Instruments LM337 Texas Instruments NE5534P Analog Devices AD847AQ (Ceramic PGA) Potentiometer Alps RK097 Selector Alps On/Off Matsushita Wiring Quirkwire M16878 silver plated (Signal wiring) Connector Neutrik NC3FD-LX-HE (Top XLR connector) Fischer connector S103 / Neutrik RCA Neutrik NRJ6HM-1-AU (Top 1/4’’stereo jack) Neutrik NAC3MPA (Power socket) (Above components are subjects to change without prior notice) Specifications Level 10Hz → 100kHz ±0.5dbm (0dbm@XLR) 20Hz → 50kHz ±0.1dbm (0dbm@XLR) THD+N 10Hz → 40kHz ±0.05% (0dbm@XLR) Phase 1kHz < 0.03℃ 100kHz < 9℃(0dbm@XLR) Gain 6.2dbm (0dbm@XLR) Noise 10Hz -110dbm 1K -130dbm 10K -135dbm (Neutrik A2D-Audio Measurement System) Headphone 16Ω → 600Ω Power Supply DC ± 20V (Internal regulator circuit, suitable for DC ± 20V→ 24V) |
#2 |
The noise level
#3 |
Hi kawo,
Nice realization. I don't see any output on the picture except headphone on front panel! Is it only a headphone amplifier. |
#4 |
HPA-1
... means usually Head Phone Amplifier, HPA A good headphone amp can of course be used as a preamplifier, too. Can it drive headphone, it can drive most other low level loads.
lineup |
#5 |
Hi: Eric
Yes,both headphone amplifier,Preamplifier. replacement the RCA to Fischer connector S103 -3way,than have one output and two intput. |
#6 |
Power on
#7 |
balance to unbalance
#8 |
main circuit (R-CH)
#9 |
That looks pretty but are you also willing to post the citcuit diagram ?
#10 |
Hi: Joachim
I am sorry.HPA-1 for sale in Hong Kong.I can't post the circuit. |
| preamplifier | Giorgos3924 | Tubes / Valves | 15 | 8th April 2012 12:27 AM |
| Why do you need a preamplifier? | globalweb | Solid State | 54 | 14th October 2007 04:47 PM |
| Preamplifier | aguantesoda | Solid State | 24 | 8th September 2006 02:39 PM |
| help with preamplifier | skobo | Solid State | 9 | 15th July 2005 12:54 PM |
| preamplifier | janey | Tubes / Valves | 4 | 28th November 2001 11:31 PM |
| Page generated in 0.12259 seconds (79.71% PHP - 20.29% MySQL) with 11 queries |
