Tas5630+smps+aluminum case finished!new year coming! - Page 33 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 15th November 2012, 08:21 AM   #321
authlxl is offline authlxl  China
SINEWAVE ELECTRONICS CO.,LTD
Send a message via MSN to authlxl
Default G36D manufacturing now, poster here
Originally Posted by authlxl View Post
We take some G36D photo from our line today, share here.Assembling silver panel now,black panel have not finished now.
more details here:
http://www.aliexpress.com/store/prod...682430450.html
Professional switch power amplifier manufacture,www.csinewave.com
Old 16th November 2012, 05:59 AM   #322
Hi Authlxl,
great it is out. Right on for Christmas,
one question: You state the programmable adjustment for the DSP for Speaker and Room effects. Is software for the DSP programming included, or how do I access the DSP?
Cheers!
Andy
Old 16th November 2012, 02:07 PM   #323
we have answered your questions here.
G300V21 turn off and on time a bit long, about 10-30s. because it have special circuit to protect the TAS5630 chip.soft on and fast repeat reject .
New versions G300V30 will finish next week,
Main Features:
1.Power out:
2x240Wrms/4ohm(1%THD+N)
2x125Wrms/80hm(1%THD+N)
2.High Power Resonant SMPS and fixed 50V DC/12A support.
3.Four layer PCB, well routing and better EMI .
4.Fast on and off .
5.Special PWM out good indicator circuit.
6.Variable Fan cooling system, 12V DC brushless fan necessary.
7.110V or 230Vac power supply.
8.Auxiliary Power out: +/-15v @200mA and +5V@500mA
9.High level active MUTE function.
10. Boot noise suppression and without output relay soft start circuit
We finish first version G300V30 board testing now, sound better, and works well, all performance looks excellent, attach module photos here.
Mass manufacture version will revise it as black PCB silkscreen version.
Same size as G300V21, it is Hi-End version, cost high, Price high.
Two type of this board , stereo module and mono module.
Old 18th November 2012, 02:43 AM   #324
Taterworks's Avatar
Great news. The layout looks very clean with the solid capacitors and the new chokes. As a benefit, the new solid capacitors won't dry out or leak with age. I look forward to testing it out.
Will the G300V30 board be able to be installed in an existing Genius G300 amp chassis? It looks like it would only require removing and replacing some screws and wiring harnesses, and soldering in the power LED wires.
If it works, but you don't know why it works, then you haven't done any engineering.
Taterworks Audio (nothing for sale)
Old 18th November 2012, 09:10 AM   #325
Yes ! G300V30 have same size and assembling screw hole as G300v21. same connector define.READY led soldering
Old 27th November 2012, 06:12 AM   #326
Smile 2.1 star speaker system use G36D
For more applications , we try to use our G36D to drive our star speaker system, surprisingly good voice come out! 2 NIS6 (6"woofer+1"driver)as left and right, 1 10' subwoofer , make together by one star stand. G36D works at 2.1 mode, bass cut about 80Hz, bass gain at mid range. one pioneer CD as source.charming voice come out!
we think our G36D have wide application , not only apply to Hi-end home audio but also suit for bar or concert.
Old 4th December 2012, 09:08 PM   #327
Any info on when a production amp with the G300V30 board will be available?
Old 5th December 2012, 09:55 AM   #328
post here! g300v30 amp finish days ago.NO.323 post
Old 5th December 2012, 03:08 PM   #329
Yes, I saw the posts and I see the board is available for purchase. But, I wanted to know if it will be available as a finished amplifier like the v21 board, ready to use.
Old 7th December 2012, 05:12 AM   #330
Oh! so easy . it is no problems to assemble it as finished amp like G300 AMP. we will upload to our store later:
Amplifier store - Small Orders Online Store, Hot Selling DSP CLASS D,TAS5630 V21 300W HI-FI,G200 AMP and more on Aliexpress.com
Hypex SMPS - When Is It Coming? Alternatives? theseum Class D 212 26th April 2009 02:10 PM
nice aluminum case cowanrg Swap Meet 5 6th September 2007 07:42 PM
Aleph-X finished... one year ago !!! GlouBou Pass Labs 6 30th June 2006 04:40 AM
Finished my Maelstrom Sonotube after almost a year of work kingdaddy Subwoofers 20 10th January 2004 11:03 PM
Copyright 1999-2017 diyAudio
