| Vendor's Bazaar Commercial Vendors large & small hawking their wares |
#231 | |
#233 |
SINEWAVE ELECTRONICS CO.,LTD
3months ago, we start our new project for high power resonant amplifier, which apply in medical equipment, class E +class D topic , engineering prototype amp finished, works well.
Resonant Frequency :1mHz +/-10% Protection : OTP/OCP/UVP/OVP/ Power out: Continuous /Burst(rms power out) Loader : Piezoelectric Transducer Ac power:230v or 110v 50 or 60Hz
high efficiency high frequency high power level,www.csinewave.com |
#234 |
We developed new module use NXP tda8920cth and tda8950th .pass our test now, works well.
T2100A 2x100w/4ohm TDA8920CTH+SMPS T2150A 2x150w/4ohm TDA8950TH+SMPS & T2100D 2x100w/4ohm TDA8920CTH+SMPS+DSP T2150D 2x100w/4ohm TDA8920CTH+SMPS+DSP Test: 1. full load shorted protect passed, 2. no load full signal out direct shorted protect passed, full signal cap shorted output and inductor shorted output passed. 3.tempreture increase over current protect passed. 4.48hours half load burning passed. 5.pulse signal test passed. 6.square wave test passed. We developed new series integrated DSP with tda class D chip(T2100D/T2150D), because we found no analog limiter performance better than dsp limiter,it can be works well with larger dynamic range, some of our customer assemble it in live show system, mic and cd signal mixed, amp burnt or tweeter burnt in worst case, but when add DSP unit, all fine.
high efficiency high frequency high power level,www.csinewave.com Last edited by authlxl; 3rd June 2012 at 06:42 AM. |
#235 |
we developed new g300 series hi-fi board, integrated tas5630 4ch mode and wide range smps and dsp unit. testing now.
#236 | |
#237 | |
We have finished g230v1.3 amp, 2ch and 4ch two type, attached pics here.
#238 | |
1mhz 1.5kW amp burning -ÔÚÏß¹Û¿´-²¥¿ÍÊÓÆµ-ËѺüÊÓÆµ
#239 |
We developed new version dsp processing active power amp modules, according to our customer reply, we set USB control port on panel, so customers can set General Parameters self .
DSP Unit Features: 1. 1 balance analog input and analog output. 2. 1 digital audio (AES3) input and digital output. 3. 4 analog output. 4. Support PEQ/xover/delay/limiter/gain setting. 5. support USB real time communication between computer and module. We use advanced DSP from ADI, 172MHz core frequency,support 170ms digital audio delay,support AES digital audio asynchronous sample rate converters. Compared with DM series active modules, it is hi-end version, debugging now.
high efficiency high frequency high power level,www.csinewave.com Last edited by authlxl; 6th June 2012 at 10:27 AM. |
#240 |
Very good!
![]() What is the specification of this one?
Shaun Onverwacht |||||||||| DON'T PANIC |||||||||| |
| Hypex SMPS - When Is It Coming? Alternatives? | theseum | Class D | 212 | 26th April 2009 02:10 PM |
| nice aluminum case | cowanrg | Swap Meet | 5 | 6th September 2007 07:42 PM |
| Aleph-X finished... one year ago !!! | GlouBou | Pass Labs | 6 | 30th June 2006 04:40 AM |
| Finished my Maelstrom Sonotube after almost a year of work | kingdaddy | Subwoofers | 20 | 10th January 2004 11:03 PM |
