| Vendor's Bazaar Commercial Vendors large & small hawking their wares |
This sounds really good! It's a Pioneer B20 on an open baffle. The woofers are Alpha 15 and the tweeter is an Eminence using the small Dayton waveguide. The woofers are crossed at approx 75Hz and the tweeter is at about 11kHz.
I will be selling this as a kit at a reduced price than buying everything separately but have not figured the price yet. Once the plans are drawn out i will offer them free so you can purchase the components from anywhere you want, build and modify. Without sounding like all i want to do is sell the kit i must say this is a very nice sounding speaker. I have been enjoying these for weeks and feel they are a great way to implement the Pioneer B20. If you like this driver you will love it with the added tweeter and woofers. From top to bottom it's very enjoyable. Open baffle removes any boxy coloration, the soundstage is wide with instruments and vocals floating in space rather than emanating from a box. Pink Floyd the Wall will creep you out (and your kids) and large scale orchestral music really sounds like a large orchestra. I will provide more details later. Godzilla |
#2 |
75hz 6db?
I must confess my favorite music is that made by the Rolls Royce Merlin. |
#3 |
>>> 75hz 6db?
The woofers roll off at 18db. Godzilla |
#4 |
Huh. I figured you'd have a hole in your midbass with that alignment. But apparently not.
#5 |
Good to see someone has finally tried this
![]() Given that the B20's list at 90db and the Alpha at 97db (an MJK OB friendly set of numbers there), what made you cross so low? R/ Jim Last edited by 2litre; 20th January 2010 at 01:13 AM. |
#6 |
Well keep in mind the Alpha is, according to Eminence's infinite-baffle loaded plot, 90 db at 75hz. The OB that Zilla is using would reduce that even more, but probably not much more. My concern would be that since the B20 is comparatively inefficient, the 100-200hz area might suffer a little considering that cancellation still does occur that high. BUT, this could probably be filled with room reinforcement, preventing the kind of midbass vocals-destroying bloat that I loathe.
#7 |
InclinedPlane,
Looking at the response graph here: http://www.eminence-speaker.com/pdf/alpha-15a.pdf I see what you mean about SPL @75Hz. But what do you mean about "cancellation still does occur that high"? R/ Jim |
#8 |
Baffle losses, where the front wave is meeting the backwave and partially 'canceling each other out'.
#9 | |
The 97dB/W/m quoted on the spec sheet is probably a peak value. The SPL curve shown must be for the driver in a box of some kind, it is totally inconsistent with a driver that has an fs of ~40 Hz and a Qts of ~1.2. Be careful with manufacturer's spec sheets. |
#10 |
It sounds funny to say the crossover is at 75hz and incorrect actually. Remember, i have an amp connected to the woofers. The woofers have a rising response so when adjusting the variable crossover the setting is at approx 75hz on the dial but the actual crossover is probably closer to 200hz. Tomorrow i will post a pic of the woofers simmed response and it may make more sense why the settings are what they are. Everything sounds great without any holes... probably more overlap between drivers than gaps. Also, the amp raises and lowers the overall volume of the woofers. So once the crossover is set to blend the woofers into the B20 then you can raise and lower the volume to adjust further. It's really just like setting up a powered subwoofer but in this case you have two 15" woofers.
Godzilla |
| Pioneer B20 open baffle -- popular tweeter | jmar | Full Range | 22 | 24th June 2011 02:27 PM |
| Murphy baffle radios [ open baffle ] | keithpeter | Full Range | 10 | 11th September 2007 08:59 PM |
| Does open baffle suffer from baffle step? | 454Casull | Multi-Way | 11 | 17th July 2006 10:25 PM |
| what effect does baffle have on open-baffle system? | kappa546 | Multi-Way | 6 | 24th January 2006 11:21 PM |
| Australians- what solid timbers for baffle? (open baffle loudspeaker) | tktran | Multi-Way | 13 | 30th November 2004 12:09 AM |
| Page generated in 0.12276 seconds (71.14% PHP - 28.86% MySQL) with 11 queries |
