| Vendor's Bazaar Commercial Vendors large & small hawking their wares |
#191 | |
Previously: Kuei Yang Wang
Location: Somewhere nice on planet earth where censorship of Ideas is frowned upon
The original Eckmiller driver had a classic Spider (that is one with legs - where the name originated - not a flat preformed colth disk) and each leg of the spider was damped using a grease-pot style damper with the addition of aperiodic damping of the rear cone by having a basket a lot like a sieve. Modern polymers can probably offer other options of resonance damping in a moving system as well. The point I was trying to make however is that we do not need to use the Amplifier to damp the cone oscillation at resonance and other then reducing drive unit cost doing so (as is common) actually does not provide any performance benefits, but many dis-benefits. Yet the practice being established we are caught in a vicious circle. Practically all Speaker makers make speakers designed for voltage drive. So if I make Amplifiers and wish to stay in business I need to make Amplifiers that drive these speakers well. Anything else is financial suicide. But with all Amplifiers being made to offer voltage drive, they will not drive a speaker designed for current drive well at all. As there no amplifiers to drive such speakers making any would be strongly prejudicial to a company's satying in business. So.... <return to the beginning of the paragraph and keep reading> This is why I gave my various experiments in the 80's on how to improve speakers "the active way" (read MFB, Current Drive etc.) eventually and instead worked on how to get good sound in the context of the systems as they are, as opposed to "how they should be". Ciao T |
#192 |
I finally found a speaker I ripped out of a karaoke machine today, and decided to see how it sounded. I also decided to test out series resistors.
I was surprised by the quality of the speaker. It has a black cloth surround, treated with what I guess is some sort of drying oil, like boiled linseed oil. Black dust cap (mylar?). The surround is large enough to accommodate decent excursion, and as such toms sound good. Deeper bass than you would expect from a 3.5" speaker. I wouldn't hesitate to say it was still a piece of crap if it didn't sound better than my $80 Kevlar cones... Unfortunately, I only have one because the karaoke machine only had one speaker... Using a 25 ohm rheostat as a series resistor, it seems to sound less militant. The sound doesn't bite so much, things sound smoother. I don't know if this is because of equalization changes. Speech is more legible. It is easier to relax while listening. (this is out of a single speaker, mono) Instruments don't obscure each other so much. Bass instruments have less bite. For this speaker at least, I would consider current drive because series resistors, to me, improved the sound. - keantoken |
#193 | |||
However, if we do so, the damping coil generates just equal electromotive forces (motional EMF and inductance EMF) as the active voice coil does, and these EMFs would then bring back the same detrimental effects that are just avoided by current drive. So, it is the mechanical damping supported by suitable cabinet filling materials that are useful, and I also think it would not take long to develop these if only some effort were put to it. Even now there are rubbers that yield free air Qm values of around 1.5; and according to my tests with copious cotton cloth stuffing, the value can yet be considerably lowered from this. Often it is not even necessary to reach to the 0.7 since with a slightly higher value, the mild boost that develops in the 100 Hz region can be used for benefit to compensate some part of the baffle step. With existing gear, it is feasible to employ some degree of electrical damping for the resonance region (a series RCL network in parallel with the driver) and keep the impedance level high elsewhere, as the benefits of current drive appear mostly in the mid and treble regions. Quote:
#194 |
I've been able to test series resistors with some hi-fi drivers lately. Results are the same. It is easier to turn up the volume without people complaining. I currently use 25 ohm resistors in stereo with Wild Burro BetsyK's. I can use such a high value since it's an open baffle and I need bass. Response is pretty flat to my ears.
I'm pretty pleased for now. I want to upgrade my amp soon, to exclude the possibility that it's simply reacting positively to the higher load impedance. Higher load impedance would change crossover characteristics, towards a more seamless crossover region AFAIK which would decrease higher order harmonics and improve small-signal linearity (it always bugs me that AB amps distort the most during the first watt...). - keantoken |
#195 |
ETM, I did buy your book and I find it informative. However, I find it to be a 'double edged sword' sort of like the books written by Doug Self. I like your use of math. This is often presented in too difficult a form in many technical papers, or ignored by many popular writers. As you show, math is important, and with some effort from the reader, understandable.
The other side of the equation is your written opinions of areas outside your general research, such as TIM. Here, you make strong statements, but they really don't help the situation and are not useful in general. I have found this in other researchers who find speaker problems fascinating, and tend to think that electronics amplification is a very poor relation in the contribution to overall sound. I still recommend this book. |
#196 | |||
Full range speakers usually suffer from cone break-up modes, that cannot be helped very much even by current drive, but even so, reducing the effects of the inductance EMF clears a lot of debris from the highs. Quote:
In general, however, I was and am hoping more attention to the main points of the book, which I have outlined in my last posting. The effects should also be quite easily reproduced with basic equipment. Quote:
BTW, there is a review of the book in the July issue of Audioxpress, but, as one can expect, it concentrates mostly on the bass region and resonance damping, omitting the main arguments presented, notably the effects of inductance. More on that later. |
#197 |
First I apologize for jumping in this late. This topic is very similar to one that I have dealt with a lot in the past. In looking at the history of the last 50 years, it appears that not all speakers are designed to be 'voltage driven'. Some are what I call 'power driven'. 'Current drive' seems to be a variant of that.
Competing paradigms in amplifier and speaker design If this is regarded as a hijack, we can cover it elsewhere, but it seems related. |
#198 | |
- keantoken |
#199 | |
V is voltage, I is current, R is the load. V/R=I V/I=R IR=V VI=power Current and voltage participate in power equally. So saying current drive is a variant of power drive is no more true than saying voltage drive is the same. In fact, no amplifier can reach true voltage or current drive, though they have made heroic efforts. Any amplifier can only have an impedance between zero and infinity, and so they are all limited to some extreme of power drive. The only factor is the balance between current and voltage drive. If the amplifier has an impedance higher than the load, it is mostly current drive. If the amplifier's impedance is below the load, it is mostly voltage drive. And an amplifier with impedance equal to the load will be balanced voltage/current drive, which is closest to what you call power drive. I'm not sure if it is possible to make an amp which has balanced drive regardless of the load, however you can make a constant power amplifier for a fixed load. - keantoken |
#200 | |
Anyway, it is true that the prior art (tubes) had variable output impedance and so there was no 'current source' model. That is why I call it the Power Paradigm. It is still around today in active use- any SET is operating in this way. Tomick, an Electro Voice engineer, wrote an article about damping that speaks to this issue, and proposed a circuit that allowed you to set the amplifier's response to deal with a wide range of speakers, some requiring a DF of 20:1 and others needing 0.1:1. Missing Link in Speaker Operation As we all know, the industry settled instead on the compromise of the Voltage Paradigm. It is a compromise and the Power Paradigm has a lot of advocates as a result! I think the most telling is that the ideal Voltage Paradigm specs that resulted seem to tell you nothing about how the amp will sound, other than once you know what the specs mean, you know the amp will likely sound a little harsh. |
| $7500.00 chipamp revealed | sendler | Chip Amps | 36 | 27th February 2009 01:25 PM |
| tube amplifiers for sale.... | Nanook | Vendor's Bazaar | 0 | 30th March 2008 05:37 AM |
| why the fad with tube amplifiers? | XxGoKoUxX | Car Audio | 20 | 27th February 2008 11:21 AM |
| Altec Tube Amplifiers | peter hawthorne | Tubes / Valves | 0 | 16th August 2007 10:31 AM |
| DC Tube Amplifiers | SY | Tubes / Valves | 14 | 1st November 2006 01:59 PM |
