| Vendor's Bazaar Commercial Vendors large & small hawking their wares |
These days I finished the TDA1541A DAC just for fun.
This DAC apply one TDA1541A for each channels for real balance output. I apply the passive I/V change, I think passive IV change sound relax than active IV change. The output is two diamond amps, the LPF only apply -6DB/oct. There is a programmable Cyclone 2 as the digital filter, it design can work on NOS or OS mode. In OS mode, it can setting work on 2X , 4X, or 8X oversampling , and the stopband attenuation can setting at -50DB, -90DB or -130DB. Because apply the Cyclone 2 chip , I can let the TDA1541A work in one channel for balance, unlike apply the SA7220. |
#2 |
Some other photos
#3 |
Man, that looks absolutely IMPRESSIVE.
Any solution is a compromise. |
#4 |
The DAC working without any couple caps and DC serve, the building is quite difficult, I want to measure and match the transistors two times to keep the output offset near 0V.
The power supply is large, it apply 5 units transformers, and 30 groups transistors PSU . Here is some photos while building. |
#5 |
I'm with ratza.
#6 |
Sometimes a square peg fits a round hole just fine
OMG!! thats some serious...errmmm 'discrete' power supply action; in fact they need to come up with another word instead; seems far from discrete.
#7 |
I conside the PSU very near the signal circuits is better than separate, can avoid the cable effect the SQ and sound color. But this just different viewpoint by different designer.
#8 |
Wow! Looks good! So, how is the sound?
#9 |
I agree it looks impressive. Some thoughts though:
- are the signals reclocked after the cyclone? I'm wondering about jitter. - the cyclone seems overkill. With a pmd100 you can easily get the same setup (ok, without nos and filter settings). And not easy to get anymore, but still. - looking at the block diagram, the output current has to travel a long way from left to right dac output. mmm.. Just my 2 cents without having details. A schematic would help :-) Had a look on the website, they actually do have designs with pmd100. Curious.
GuidoB |
#10 |
| Help me balance SQ and SPL and weight for my sub | eRiCdWoNg | Subwoofers | 6 | 25th February 2007 02:39 AM |
| Quad balance | ginsner | Solid State | 4 | 16th August 2006 09:04 PM |
| Why is Q balance required | goldyrathore | Multi-Way | 6 | 17th May 2004 12:04 AM |
| Combing effects: How real in "real" rooms? | smeade1079 | Multi-Way | 3 | 10th March 2003 01:32 AM |
| Balance control | 2Bak | Pass Labs | 4 | 11th July 2002 08:07 AM |
| Page generated in 0.11221 seconds (78.28% PHP - 21.72% MySQL) with 11 queries |
