| Vendor's Bazaar Commercial Vendors large & small hawking their wares |
300 watt TUBE/MOSFET hybrid amplfier module.
600 watt TUBE/MOSFET hybrid amplfier module. 900 watt TUBE/MOSFET hybrid amplfier module. 300 watt MOSFET amplfier module. 600 watt MOSFET amplfier module. 900 watt MOSFET amplfier module. More info at: www.ckp-railways.talktalk.net\amplifier.htm
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#2 |
Are these modules using Lateral Or Vertical Mosfets?
Your web page suggests the use of a 40 0 40 AC transformer so 56 0 56 DC To output 450w RMS into 4 ohms the Output needs to swing approx 120v peak to peak. Could you quote the Rail voltages that you use on your '900W' Module? |
#3 | |
40 - 0 - 40 is a minimum and is playing safe. The module requires +/- 60 volts to get the maximum output. However the capacitors are 63 volt so some care needs to be taken not to go over approx 60 volts. I have done a couple of orders for modules with 80 volt capacitors.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. Last edited by nigelwright7557; 2nd September 2009 at 12:08 AM. |
#4 |
#5 |
#6 | |
| Lateral Mosfet Amplifers 250W - 2000W RMS Power Amplifier modules | Class-D Design | Vendor's Bazaar | 162 | 27th October 2011 01:17 AM |
| headphone amplifier = tube + mosfet | sparkle | Headphone Systems | 25 | 23rd June 2009 03:52 PM |
| Hybrid Tube / Mosfet Amplifier | poynton | Tubes / Valves | 8 | 10th August 2007 06:32 PM |
| Page generated in 0.09472 seconds (72.98% PHP - 27.02% MySQL) with 10 queries |
