6 Volt Sony Power Amplifier
Modified Sony XM-554ZR power amplifier for 6 Volt system. The modification was tested form 5 to 7.2 volts, it sounds fantastic.
Connect the ignition switch or a toggle switch to the remote terminal. The head unit doesn’t have power until the amplifier is on, so you can’t use the remote form the head unit. The 12 V memory output is on all the time for the head unit memory. The head unit 12 V output will also power an iPod/MP3 12 V adapter or Satellite Radio.
Now you can have an awesome sound system in your 6 volt.
Specifications
http://www.thesamba.com/vw/classifieds/detail.php?id=796241
