| Vendor's Bazaar Commercial Vendors large & small hawking their wares |
#1 | |
Apa's DIY
any chance of ordering 4 sets from you? (I sent you a private email but without the input selector switch), but now I am very interested with 3 way input selector. gychang |
#2 |
Hi there,
Im working on some cool stuff now, new housing for my own amp using my own PCB's. i might sell it also if there is interest for it. i want to make something like i have running now, a TA2020 MKIII with my valve amp ( running 24/7 now in test phase ) and a SMPS to power it. and i add 2 VU meters for fun ill show a photo. Greetings! Arjen
Always check the power supply... and my spelling... |
#3 |
im getting a new backside, the connectors are not positioned nicely. the speaker connectors are too close to the side.
also the VU meters will be 1mm deeper and get a shiny edge around them
#4 |
Hello Arjen!
Which tripath chip is inside this amp on last two posts and how much will be the price range if you decide to sell them? |
#5 |
Hi there,
This amp can be equipped with TA2020 or TA2024, witch ever you prefer the price indication is around 120 Euro, i hope i can get that price down, but it depends on quantity and my negotiation skill in Chinese ;-) for that you get a fully finished amp with 3 channels input valve pre-amp, MKIII board and 3.5A SMPS powersupply inside. i hope it will be done around 2 weeks from now. Greetings! Arjen Helder
#6 |
this board comes ready built, right?
#7 |
Hi Arjen,
what kind of preamp you use? CF? Tube? PS voltage? I like to use your old green boards (modified) with different tubes headphones amps, gain is too much, but I like how it sound. Zigis. |
#8 | |
Can you describe the difference of the sound using or not the valve preamp?? I'll be watching your ebay for new things =D Thanks in advance! |
#9 |
Whelibob,
Yes, i do not sell kits, just fully finished boards. Zigis, i use a double triode 12AU7 valve for this, the amp was designed for me by a friend that used to design for Siemens ( 20 KW FM transmitters, enz ) Its more a Valve Buffer, it does not amplify, it changes the sound so that it has that tube warmth and smoothness, making the TA amps sound like a valve amp. the plate voltage is made with a cascade and a NE555 IC, very simple, no noise and a band with or 253 KHZ at -3DB, so, plenty! the NE555 works at around 40-50 KHZ switching frequency. the plate voltage is around 40 volts, more than enough since i don't want gain! the tube board only needs 12 volts, the NE555 works off of that. Greetings! Arjen Helder
#10 | |
Apa's DIY
waiting for those with VU meters and 3 input selector model... gychang |
| Page generated in 0.10799 seconds (78.26% PHP - 21.74% MySQL) with 11 queries |
