| Vendor's Bazaar Commercial Vendors large & small hawking their wares |
I have designed and marketed a 900w MOSFET amplifier module on ebay.
It includes the amplifier plus smoothing capacitors on board. Search for 900w amplifier module on ebay.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#2 |
cant find anything
#3 |
I believe this is it.........
120419740136 It only shows up on the UK ebay page when you search as mentioned above.
"If you don't like funerals don't kick sand in ninja's face." |
#4 |
ok thanks, found it
Looks neat, a bit simple But price ok May work fine fore woofer amp But I would like a bit more information From experience, without knowing more, I wouldnt use much more than max 2x 50Vdc Thats about half the promissed output, if its 8ohm But maybe its 4ohm, doesnt say I have old 2x33Vac trafos that would suit it, fore 150watt, 8ohm |
#5 | |
Your transformer would work fine with it. The amplifier is rated at 450WRMS into 4 ohms.
#7 | |
900 watts peak.
#8 | |
I have also added a 600w and 300w modules to ebay.
#9 |
Speakerholic
No point in talking peak with these guys Nigel. Makes 'em suspicious. Far too vague of a term.
#10 | |
In that case they are 150WRMS, 300WRMS and 450WRMS into 4 ohms.
| Sub Amplifier Module Manufacturers | schmeet | Subwoofers | 6 | 4th October 2011 04:23 PM |
| DIGI-125 Kit Amplifier Module | mrfeedback | Solid State | 107 | 23rd May 2011 07:00 AM |
| Help me troubleshooting amplifier module | fosforo | Solid State | 15 | 7th November 2006 11:59 AM |
| Equilog PWM amplifier module? | TroelsM | Class D | 7 | 12th November 2005 12:32 AM |
| FS: 350 Watt Power Amp Module $100.00 | Zero Cool | Swap Meet | 3 | 28th May 2005 12:37 AM |
| Page generated in 0.09938 seconds (78.57% PHP - 21.43% MySQL) with 10 queries |
