| Vendor's Bazaar Commercial Vendors large & small hawking their wares |
#31 |
HM, the C-Horn is a commercial product, so I'm not at liberty to disclose more than what I already have.
The other horns I have built that are in the public domain are the Big Fun, the Medallion II, the Fostex BK16 and BK20....plus various large Tannoy vintage horns...GRF etc. I have also built a variation of the BK20 using my own modded ideas to test throat sizing, curved horn paths etc. I have also built (and am licensed) to build Jim Carfrae's Little Big Horn...this uses a tractrix 2.0m horn path. His drawings are not public. I have also done a little work with David D on a Curvy Bruce horn. Others are well into sims and models...where I tend to get on and build samples...which just happened to have worked out well. Sorry if this radical and risk-taking approach may not be to your liking. Kind Regards. Andrew. |
#32 |
Hello Human bin,
the RDH20 is a double horn, the B200 horn is no real bass horn if you see inside, may be you read about what in the middle: http://www.hm-moreart.de/11.htm atilsley, commercial, than you have not post it here its DIY, commercial, and you donīt know the flare rate, and no measurement at all? poor customers.
http://www.hm-moreart.de |
#33 |
HM
I'll choose to leave your unsavoury comments alone. All the best. Regards. |
#34 | |
But Andrew will supply them as DIY kits in highly customised form. So there is a definite DIY component here and I for one do not mind showing us what he does. Re horns, I have limited experience as I do other kinds of designs. But I have had this discussion with Andrew that I suspected that some drivers, especially Lowthers, are too over-damped, even for horns - their very Low Qe is what gives them such high efficiency (and sensitivity) but also can act as a brake at LF. But since I had a pair of B200 and had an opportunity letting Andrew try them in horns, why not? I heard them in one of his horns and liked what I heard, in which case I suspect others will as well. Re measurements, these can be arranged in time (I have the necessary facilities right here) and perhaps doing it with the Visatons in the C-Horns would be a good idea and also instructive. But in the meantime we can listen and enjoy them. The rest is academic Joe R.
The "Elsinore Project" DIY Speaker System Webmaster: Custom Analogue Audio, JLTi and... "The Linear Current Loudspeaker" |
| Anyone built a TB W5-1611 Horn? | Herr_Mo | Full Range | 3 | 2nd July 2009 08:10 AM |
| Horn loading a built sub | qguy | Subwoofers | 3 | 25th October 2008 10:32 AM |
| Custom-Built 35Hz 145 dB Bass Horn...FOR SALE | methylamine | Swap Meet | 9 | 15th August 2008 04:07 PM |
| crappy pic of a half built horn | nanl2053 | Full Range | 36 | 16th November 2007 07:55 PM |
| Anybody built the Fostex horn designs? | leadbelly | Multi-Way | 3 | 27th May 2003 10:11 PM |
| Page generated in 0.08685 seconds (78.23% PHP - 21.77% MySQL) with 10 queries |
