Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 11th February 2009, 03:39 PM   #1
Thumbs up 4000 lumen projector avaiable under $2000USD!
Hi, I have found a supplier which sells 4000 lumen projector at less than $2000, here are the specs
Display DLP
Display Ratio 4:3 & 16:9
Native Resolution 1024*768 dpi
Max Resolution 1600×1200
Brightness 4000 ANSI lumens
Contrast 2300:1
Speakers Internal 3W speakers
input 1 VGA(15-pin D-Sub)、1 DVI-D(24-pin,HDCP)、component (RCA jack,2 audio)、S-Video(Mini-DIN 4 pin) 、Audio(mini jack)
Lens Focus 1.15:1,F=2.6-2.8, f=26.01-29.84mm
Projection mode front/rear/ceiling/rear ceiling
Projection Size 23.4-350 inch
min/max distance 1-13m
lamp power 230 w
lamp hour 3000 h
Power Universal AC 100--240V~ 50 / 60 Hz
Power consumption 290 W
Dimensions 300*244*88mm(L*W*H)
Weight 3.5 Kg
other projectors are also available for as low as $300
if anyone is interested please email me at mind.unity@gmail.com
Canadians, Buy my projector (4000 lumen OHP, Sharp QA-1400 ) before it goes on Ebay! fenixviper Swap Meet 6 18th August 2005 04:17 PM
Page generated in 0.06364 seconds (63.70% PHP - 36.30% MySQL) with 10 queries
