| Vendor's Bazaar Commercial Vendors large & small hawking their wares |
#81 |
OK, thanks for your explanation. It's very easy to get paranoid about counterfeit parts nowadays.
col.
http://www.minirig.org.au |
#82 | |
col.
#83 |
i dont used softstart.. thanks
#84 |
do the lights go dim when you turn it on?
Iv'e been using these: http://www.ska-audio.com/diy/softstart.html The kit is very cheap and effective. No need for an additional winding or a separate transformer. Maybe christi could come up with a connexelectronics softstart ![]() col.
#85 | |
![]() i'm still trying to find suitable softstart.. thanks |
#86 |
Keep it simple with 1 passive component, it is called NTC.
See link ; http://www.ametherm.com/Inrush_Curre...rrent_faq.html These are used by many manufacturer and they work great. Eric |
#87 |
My TA3020 Amp is playing for 2hours now with moderate levels..
I've measured the temperature of the heatsink and its around 57-58degrees Celsius .. I can only put my fingers on the heatsink for 3secs.. I will put a small fan to help lower the temp. thanks |
#88 |
Finally managed to get rid of the ground loop/hum and now have my TA3020 in my tri-amp system powering my compression drivers. Some photos of the amp are here:
http://minirig.org.au/2009/02/14/min...ripath-ta3020/ please leave comments on the blog ![]() col.
#89 |
Col, do you have any problems of overheating.
Nice work. |
#90 | |
I am only running my amp at low voltages (42-43v) though and at the moment it is only powering the high frequency drivers in a tri-amp system, so it really is not doing a lot of work. Also, my case has very good ventilation. col.
| 8 GB150D amplifier modules and 4 GB150S2 power supplies from ska-audio.com | Didush | Swap Meet | 0 | 1st August 2009 09:06 PM |
| LM3886 Chip Amplifier Stereo PC Boards, Kits, and Assembled & Tested Modules | Jackson Audio | Vendor's Bazaar | 2 | 8th April 2007 12:17 AM |
| Audio amplifier project kits | syber | Chip Amps | 2 | 6th December 2006 07:42 PM |
