NEW Audio amplifier kits, modules and many others. - Page 73 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 18th September 2011, 04:25 AM   #721
Banned
Send a message via Skype™ to Cristi
yes, can be supplied from any voltage in range of +-12V to +-60V if the voltage regulator ballast resistors are properly chosed.
Old 18th September 2011, 06:01 AM   #722
wingman is offline wingman  Denmark
Then I would like to buy 3 of them, setup to support the voltage range from my previous post.
bass is music
Old 19th September 2011, 06:55 AM   #723
Banned
Ok, please leave a note when you order them about the required supply voltage.
Old 1st October 2011, 01:21 PM   #724
Banned
Long awaited TA3020 KIT available: Connexelectronic
Old 9th October 2011, 12:01 AM   #725
formula 22's Avatar
Hello Cristi!
Display the schematics or project for SMPS +/-35V/2x5A.
thanks
Old 1st December 2011, 03:01 PM   #726
Banned
Linear Power supply with auxilliary power supplies and complete protection for class D and T amplifiers: Connexelectronic
Old 3rd December 2011, 04:56 PM   #727
Hi Cristi
I received the SMPS today.
Thank's a lot, You are really a good guy!!!
jack
Old 24th January 2012, 04:39 AM   #728
Abelma is offline Abelma  Belgium
The BIPS module acctually needs +-12V for proper operation, but when is used with TA3020 amplifiers or similar, it can be powered from higher voltage, such as +-40 to +-60V, on board there are 2 resistors and 2 zenner diodes to limit the voltage to 12V. if the auxilliary output of any smps is used, which provide +-12V or close value, the resistors value can be reduced or even eliminated and supply the board from the aux. directly.
Hi I bought a BIPS and waiting the delivery. Do you have the schematics and other documentation please ? Thx
Old 26th January 2012, 05:30 PM   #729
Banned
I attached the BIPS schematic on the forum in few places, i will do it again here.
what need to consider is R5, R16 which set the overall gain, in this case 1. if other value is needed, can be chosen by the ratio of R5/R3 for left channel and R16/R22+1 for right channel. the op-amps are supplied through the 1W resistors and 12V zenner diodes. the resistors should be chosen to allow BIPS to be supplied with the available voltage, which can be in range of +-12V to +-60V. for +-12V, 33-56R resistors should be used, and for +-60V 2k2-2k7/1W resistors should be used.
Old 26th January 2012, 07:28 PM   #730
Is BIPS attenuating the signal by 20dB before entering the opamps?
regards Andrew T.
Sent from my desktop computer using a keyboard
8 GB150D amplifier modules and 4 GB150S2 power supplies from ska-audio.com Didush Swap Meet 0 1st August 2009 09:06 PM
LM3886 Chip Amplifier Stereo PC Boards, Kits, and Assembled & Tested Modules Jackson Audio Vendor's Bazaar 2 8th April 2007 12:17 AM
Audio amplifier project kits syber Chip Amps 2 6th December 2006 07:42 PM
Copyright 1999-2017 diyAudio
