Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 1st January 2010, 04:00 AM   #591
Kooka is offline Kooka  Italy
Kooka's Avatar
Originally Posted by sgarbialan View Post
In theory the pin 1 of the molex connector, if I understood well, should be connected to the +5V to activate the mute function.. but in the molex connector there's no +5V pin available as in the other boards based on the TA3020.. so probably connecting it to a point of the board where there's the +5V used for the TA3020 or an external +5 (through a series resistor of 100ohms for security) should do the job.. In the datasheet of TA3020 and in the documents it says just "a logic high will activate the mute function".. I guess that this "logic high" should be the +5V but maybe I'm wrong. At any rate the mute function is not needed for anti-thump if you use the external speaker protection board..
Yes, I checked and tha logic high should be a +5v taken somewhere. But why not taking to the molex connector even those +5v if the idea was to use those +5v on the board? Bah, we'll see. Thanks by now, and happy 2010!
Old 1st January 2010, 05:12 PM   #592
If you look to the v3a and v2 there is the +5V pin in the molex connector.. only the v3b and v3c have a smaller molex (6 pins instead of 8) and they don't have the +5V..
Old 2nd January 2010, 04:25 AM   #593
First of all, Happy New Year to Everybody !!!!
on the latest version of the TA3020 amplifier boards i removed the +5V out from the connector to make sure that this voltage will not be improperly used to supply other stages which will require different voltage or higher current than what can be provided, and alterate the amplifier performances or even damage. anyway for pull-up the mute pin the 5V can be picked up from the board, the small 470uF cap which is on the bottom left of the board, the closest one from the mounting hole. this operation must be done with extreme care, to not short-circuit something or damage the board.
www.connexelectronic.com complete assembled amplifier and SMPS
Old 3rd January 2010, 01:40 PM   #594
Kooka's Avatar
That capacitor should be C31, at least on the V3b board, right?
Old 4th January 2010, 10:14 PM   #595
Kooka's Avatar
Originally Posted by DIGORA View Post
HY cnx
Do you have an idea to use a vertical heatsink of an amplifier box for the TA3020 ?
I have an empty box like this : http://www.audiophonics.fr/images2/4...PANTE-5U_1.jpg
8ch off TA3020
Do you have a pic without heatsink of the V3C ?
Hi, that case is from Hifi2000, you can see more of them on their website. Many very nice cases...
Old 14th January 2010, 05:58 AM   #596
i would like to continue the discussions from this thread here: Connexelectronic - diyAudio
each category at it's section.
thank you.
Old 15th February 2010, 10:23 AM   #597
New products are coming soon. keep close !!!
Old 21st March 2010, 11:23 AM   #598
Originally Posted by fb View Post
Is it possible to have the TA3020v3b board fitted with IRFP4228 mosfets? From what I read it is the best option - allows higher output and cooler running.
The IRFP4228 MOS-FET's are now available as option for TA3020v2, TA3020v3b and TA3020v3c amplifier modules:
Connexelectronic
Old 24th March 2010, 10:16 PM   #599
Hi,Cristi,would like to know if the 1000watts peak power is 1000watts with an output of +-45V as well as +-55v or if it's current limited and give more power in 55 volta than 45volts.And if it's current limited what is the peak current we can have from the output.
Also interesting to know if for example we can have 1000watts peak for each side of the
supply when driving amplifier.thanks
Old 25th March 2010, 10:06 AM   #600
I forgot to mention that my question was about the power supply smps10000.
8 GB150D amplifier modules and 4 GB150S2 power supplies from ska-audio.com Didush Swap Meet 0 1st August 2009 10:06 PM
LM3886 Chip Amplifier Stereo PC Boards, Kits, and Assembled & Tested Modules Jackson Audio Vendor's Bazaar 2 8th April 2007 01:17 AM
Audio amplifier project kits syber Chip Amps 2 6th December 2006 08:42 PM
Page generated in 0.13199 seconds (84.33% PHP - 15.67% MySQL) with 11 queries
