| Vendor's Bazaar Commercial Vendors large & small hawking their wares |
#571 |
well do you know what is its max working voltage? if so, then you pretty much know what it can do, is that not so?
#572 |
Cristi said the max voltage of the TA0105A is +-200V. By my calculation that gives a bridged power of 6400W into 8ohm with ~28amps of current. My suspicion is that the TA0105ARB board as currently available will not be able to handle that.
For +-80V, 1024W with ~11 amps current seems more reasonable. My knowledge is not great, but I think without some more information from Cristi about the mosfets, PCB etc., we cannot know for sure. |
#573 |
the available board can deliver up to 500W at 4 ohms and 280W on 8 Ohms.
i mention that the ic can work at up to +-200V but in a practical design will never be used at such voltages. up to +-140 to 160 is resonable. there must be a safety margin of at least 25% for reliable usage. even so, with +-140V rails you can get huge output power even in single ended, not to talk about BTL. for this, must use a complete redesigned pcb, with multiple output MOS-FET's and a much more tight layout, prefereable 4 layers with 3 oz. copper, very short and wide tracks, ground planes, etc....
www.connexelectronic.com complete assembled amplifier and SMPS |
#574 |
You should design such a board
I do not need such high power though - it looks like the stock board will do for me. What is the idle power usage of the TA3020 and TA0105A boards? Thanks for your help |
#575 |
i started the design of such board, but i abandoned the design, since the TA0105A is obsolete already and i have just few pcs. left for the boards which i already have. i cannot get new stock at a resonable price, but probably i will make the design with the chipset used for the TA0105 ic.
the idle current of the TA0105 is arround 70-100mA on power rails, 50mA on 5V and 250mA on 12V. the TA3020 idle current, i measured and post on a previous page of this thread few months ago.
#576 |
HY cnx
Do you have an idea to use a vertical heatsink of an amplifier box for the TA3020 ? I have an empty box like this : http://www.audiophonics.fr/images2/4...PANTE-5U_1.jpg 8ch off TA3020 Do you have a pic without heatsink of the V3C ? Thanks Last edited by DIGORA; 15th December 2009 at 06:35 PM. |
#577 |
in this configuration is hard to use a vertical heatsink unless you use some heatslug to conduct the heat from the transistors and ic to the heatsinks which will be attached at the edges of the board. if i will have request for such arrangement, i can order both the vertical heatsinks and the heatslug.
i will make a photo of the module without heatsink later, and post here. it looks very similar with v3b but is bigger size due to the capacitors and speaker protection.
#578 |
I just found a copper plate maybe large enough to use them
what is the size of the Heatsink ? |
#579 |
Perhaps a question other people might have as well: if I want to replace the rectifier bridge in the TA3020 V2 amp with diodes, which values should those have?
#580 |
same or higher then rectifier bridge itself
| 8 GB150D amplifier modules and 4 GB150S2 power supplies from ska-audio.com | Didush | Swap Meet | 0 | 1st August 2009 09:06 PM |
| LM3886 Chip Amplifier Stereo PC Boards, Kits, and Assembled & Tested Modules | Jackson Audio | Vendor's Bazaar | 2 | 8th April 2007 12:17 AM |
| Audio amplifier project kits | syber | Chip Amps | 2 | 6th December 2006 07:42 PM |
| Page generated in 0.11375 seconds (75.77% PHP - 24.23% MySQL) with 11 queries |
