Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 1st December 2009, 02:51 PM   #551
ashok's Avatar
Default You have pm
Hi Cristi,
You have a pm !
Does the TDA8920 chip require isolation ( mica) from the heat sink ?
Ashok.
AM
Old 2nd December 2009, 12:18 AM   #552
inept is offline inept  United States
Originally Posted by inept View Post
I purchased (4) TDA892x Amp V2 with TDA8924TH, and 10000uf 35v capacitors.
I plan on bridging 3 of them to run my L,R, and center speakers at 4ohms.
The other one I will run in stereo for my 8 ohm surround speakers.
Cristi recommended "2x18 to 2x20V AC , the current should be at least 4A, better 5A. the transformer power rating for each module should be at least 180W."
Can I use 1 of these transformers to power two of the modules,, two transformers to power 4 modules?
Antek - AN-2220 ?
Would it be better to use separate transformers for each module?
OOPS! that link should have been for the AN-4220 400va transformer
Antek - AN-4220
Old 2nd December 2009, 06:15 AM   #553
ashok's Avatar
Default TDA892X module + heatsink
The TDA892X is slightly thinner than the Bridge rectifier on the board. This will enable placing an insulating washer between the chip and the heatsink. What sort of insulator. Silicone or mica sheet ?
Thanks.
AM
Old 3rd December 2009, 07:41 AM   #554
kp93300 is offline kp93300  Malaysia
Default Broken link
Hi Cristi,
The link for LME amp, soft start and the speaker protection circuit appear impaired.
Can you repair them please as I need info to wire them up
thanks
kp93300
Old 4th December 2009, 12:27 PM   #555
Originally Posted by ashok View Post
Hi Cristi,
You have a pm !
Ashok.
between the ic and heatsink must place insulation. the ic pad is connected to negative rail.
Originally Posted by kp93300 View Post
Hi Cristi,
thanks
kp93300
it should work now, please try again
Thanks.
both of them are ok, as long as they make a tight contact and you add some silicone electrically non-conductive compound.
www.connexelectronic.com complete assembled amplifier and SMPS
Old 5th December 2009, 03:28 AM   #556
fb is offline fb  Australia
Cristi, what class D/T board would you recommend to connect directly to a high sensitivity (110db/w/m) driver to avoid hiss? TDA892X?
I notice earlier in this thread you mention a 2kw smps, is that happening? What voltages would it supply?
Is there a fan output on the A1000SMPS? Does it need any precautions to reduce EMI?
Old 5th December 2009, 04:13 AM   #557
for lowest noise i recommend TDA892x boards.
i'm currently working at the design of the bigger smps. there will be few output voltage options, starting from +-25V to +-90V.
the A1000SMPS has a auxiliary voltage output adjustable from 5 to 12V with max. 0.5A which can be used for a fan or other amplifier stages. it's ground is isolated from the main output supply, so can be used as bias supply referenced to any rail or gnd.
Old 6th December 2009, 01:48 AM   #558
Is it possible to modify the input gain of TDA892x V2 board via pot? I'm not sure if the datasheet applies to this version of the board.
Old 6th December 2009, 03:51 AM   #559
Default ta3020v3c
Hi CNX, what changes have been made to the TA3020v3c version? Would you recommend the smps1000 for this amp? Are any other components required besides these two things? Also would you still recommend the BIPS (180 phase shift) for this amp?
Another question... somebody earlier mentioned changing the mos-fets on the 3020 boards to IRFP4228 for higher output and cooler running... could you do that?
Old 6th December 2009, 07:33 AM   #560
the gain can be changed only externally, attenuation with potentiometer. the TDA892x IC's has fixed gain which cannot be changed (not very simple)
the manual is similar with the previous version, the boards are based on the same schematic, only the layout is changed.
on the TA3020v3c i added speaker protection circuit, bigger capacitors for the power supply (35mm diameter) and rectifier bridge. the amplifier can be used with smps as well, and the bridge can be removed in this case. BIPS can be used if the supply voltage is close to the upper limit, +-60V to prevent turning ON/OFF when the voltage boost over the maximum limit.
this board can be used in BTL mode directly even without BIPS, by simply connecting one resistor which will bring inverted signal from the output of one channel AO to the input of the other channel AO.
the MOS-FET's can be changed, with IRFB4227 which is one of the best in his class, the efficiency will be improved a little but the output power is still limited to the maximum rail voltage which the IC can admit, so there will be slight changes on the output power.
8 GB150D amplifier modules and 4 GB150S2 power supplies from ska-audio.com Didush Swap Meet 0 1st August 2009 10:06 PM
LM3886 Chip Amplifier Stereo PC Boards, Kits, and Assembled & Tested Modules Jackson Audio Vendor's Bazaar 2 8th April 2007 01:17 AM
Audio amplifier project kits syber Chip Amps 2 6th December 2006 08:42 PM
Page generated in 0.11539 seconds (85.62% PHP - 14.38% MySQL) with 11 queries
