| Vendor's Bazaar Commercial Vendors large & small hawking their wares |
| Thread Tools | Search this Thread |
#521 |
Can no one comment on my question?
#522 |
the transformer power rating and voltage can have influence on the sound. how ? first, the voltage should be within 2x32 to 2x42V AC. second, the power rating of the transformer, and the rectifier plus capacitors have an influence due to the PSRR (power supply rejection ratio) which is lower at switching amps than at class AB amps.
so, for best performance use the biggest transformer power available and large filtering capacitors. one suitable linear power supply board is the one with 6 pcs 18,000uF caps. (careful!!! has 270 Joules !!!!) this board can supply more than one TA3020 amplifier, somebody use one for 3 amps.
www.connexelectronic.com complete assembled amplifier and SMPS |
#523 |
Thx - info helps!
#524 |
Hi Christi, i done payment by Paypal with id 3PT66345N8256844V, but your site says 'no order'. Have you received order?. Thanks
#525 |
i got a payment from ca*****li@dpm.it at 7:40 GMT +8. i assume that is from you. please contact me on pm and we discusse details.
#526 |
hello cristi, I am interested in building 3020 amp .can you tell what i need to build a nice unit including ,power supply,transformer specs. ect. also can it be bridged. thanks peter
#527 |
Hi Cristi,
I issued a payment but also for me the site connexelectronic.com is not listing it , could you please confirm the order? I left you a PM..Thanks in advance , Ciao ! Last edited by hawui1; 8th November 2009 at 04:15 PM. |
#528 |
i got you payment and i process the order. i will reply to pm now.
#529 |
Perfect, thanks a lot Cristi
#530 |
Hi,Cristi , I received A1000SMPS today and It seemed to be in very good
condition but before to try I have a few questions. If I input 120Vac with remote connector open, do the supply is in standby mode? Could I use aux supply to power the remote terminal? Is it necessary to power up power supply first and apply remote supply only after power up, or could I connect aux supply (example) permanently to remote input and put a switch in line with 120vAc input for powering the supply? What is the voltage and current available from the auxiliary supply;I would like to connect a 24Vdc fan. thanks |
| 8 GB150D amplifier modules and 4 GB150S2 power supplies from ska-audio.com | Didush | Swap Meet | 0 | 1st August 2009 10:06 PM |
| LM3886 Chip Amplifier Stereo PC Boards, Kits, and Assembled & Tested Modules | Jackson Audio | Vendor's Bazaar | 2 | 8th April 2007 01:17 AM |
| Audio amplifier project kits | syber | Chip Amps | 2 | 6th December 2006 08:42 PM |
| Page generated in 0.10965 seconds (84.54% PHP - 15.46% MySQL) with 11 queries |
