Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 12th September 2009, 01:09 PM   #441
of course it's mono.
Look at the pic you posted:-
It has
one input cap,
one voltage amp chip with it's heatsink,
one output coil for the Thiele Network,
one 3pair output stage.
regards Andrew T.
Old 12th September 2009, 02:26 PM   #442
e_fortier's Avatar
Originally Posted by luka View Post
its called EQ my friend
Why should we go through all the trouble of EQ with this TA2022 amp and not needing any EQ with the amp he used to have (Cambridge Azur 640A).
Normally with any good amp. there is no need to EQ them
Cristi,
Please provide some feedback.
Thanks,
Eric
Old 12th September 2009, 03:29 PM   #443
one does not need EQ.
One cannot blame the lack of EQ for loss of quality.
I have not had any EQ nor Filters in any of my systems for about 35years and the filters I had before that were set to bypass to improve the sound quality and to hear what the producer put on the recording for me.
regards Andrew T.
Old 12th September 2009, 03:59 PM   #444
It has
one input cap,
OK, thanks...
Of course you are right, - no need to be so patronizing though
Still wondering if there are some ready-made holes at least on one side of the heatsink to screw it into a chassis...
Old 12th September 2009, 06:42 PM   #445
luka is offline luka  Slovenia
luka's Avatar
Send a message via MSN to luka
Cristi,
Thanks,
Eric
I'm not sure, but even if amp played flat or not, always will depend on listener...does he like it or not, amp is how it is, somebody likes it, some don't
Old 12th September 2009, 07:53 PM   #446
Hi Cristi,
One of my friend has recently purchased a TA2022 power amp from you based on my recommendation. He finds himself not very satisfied with the mids and high, it seems has they are lacking or not present enough in the music, the bass is great but I would like to know if this is the first time you receive this comment regarding your TA2022 PCB.
Please let me know if there is some possible mods to improve this.
Thanks,
Eric
is not the first time when i receive this comment, is the second time, first i received one mail, about 2 weeks ago, from him. i didn't reply since i am engineer, not artist and i am not familiar with the following terms: "much less open - more muddled image - less extended treble and something marginally tizzy in the high"
as i mentioned before, i perform various tests on the prototypes durring development stage, and after, on every batch and on every single pcb, to make sure that all of them are according with the desired values.
regarding TA2022, i can only say that frequency response from 20Hz to 20Khz is better than 3dB, and from 45Hz to 16KHz better than 1dB. if this values are correct, then how come the trebble are missing ?
i appreciate this comment, but to be able to change something, i need real values, not feelings given by the stimuls which are extremly subjective. also he mention about the ringing, the peak amplitude is just about 1.2-1.6V
one very important aspect which it wasn't mentioned was the load impedance, and eventually the capacitance of the passive crossover capacitors, which can have a very big impact on the quality of sound. this amplifiers are pre-filter feedback, so the load dictate the linearity.
Originally Posted by pincellone View Post
Hallo CNX,
I'm quite interested in your amp based on LME49810, but I wonder how can I put this one into a chassis, there seems to be no screw holes available or suitable points to install it. They must be located on one side, I guess...
Also, is it mono or stereo? Do I need a pair of them to build a stereo amp?
Thanks!
each module is single channel. contact me and i can make custom-made heatsinks to fit to your case or drill threaded holes.
the larger module, 500W has already threaded holes on the corners
i have few customers which bought this modules before and they are very satisfied with them. i will ask them to post some photos with their amplifiers and you can have an ideea about how to install them in the case.
Cristi,
Thanks,
Eric
if he use to listen to a specific amplifier, then is very pssible that another one to be different than te expectations. just measure the same parameters for both amps and compare them and is very possible that you will find the answer.
have he tried with diferent speakers ?
www.connexelectronic.com complete assembled amplifier and SMPS
Old 15th September 2009, 08:44 AM   #447
New Promotion for TA3020v2, TA3020v3a and IRaudamp7 amplifiers, special prices untill end of this month. TA3020v2 just 89.99 usd, complete amplifier with power supply included, requires just transformer and case.
Old 16th September 2009, 01:14 AM   #448
Default anyone tried the DA-1
Has anyone tried the DA-1 from connexelectronics?
Looks rather good - 2x300W in to 8 ohms, single supply, very efficient. I wonder what the noise floor is like.
I also note that the PDF file describing it seems to have disappeared too :/
Old 16th September 2009, 08:43 PM   #449
new product released:
amplifier SMPS, which i made open project also. schematic, pcb, BOM available here: http://www.poweramp.ro/forum/viewforum.php?f=14
for sale, there is bare PCB, kit or complete assembled and tested.
Power Supplies » Switched-mode Power Supply
Old 16th September 2009, 09:01 PM   #450
luka's Avatar
looking good!
8 GB150D amplifier modules and 4 GB150S2 power supplies from ska-audio.com Didush Swap Meet 0 1st August 2009 10:06 PM
LM3886 Chip Amplifier Stereo PC Boards, Kits, and Assembled & Tested Modules Jackson Audio Vendor's Bazaar 2 8th April 2007 01:17 AM
Audio amplifier project kits syber Chip Amps 2 6th December 2006 08:42 PM
Page generated in 0.14167 seconds (79.66% PHP - 20.34% MySQL) with 11 queries
