| Vendor's Bazaar Commercial Vendors large & small hawking their wares |
#41 |
For those of you not familliar with CD-ROM drives, try to find a Plextor CD-ROM drive, any model. These are the quietest, best built CD-ROM made. The CD-RW drives are even better.
They have excellent speed control, by far the best laser and one of the most reliable transports ever built. Go ask the technician in a local computer shop that has been around for a while. Whne they trash an old PC or server, most will pull the Plextor drives, even if they have no use for them. They are just too good to throw away. You should be able to find one for $25 or so. Good luck Jess
"If we crashed our cars as often as we crashed our computers, we'd all be dead!" |
#42 |
Sorry for the stupid question, but how do I get the data out and stream it as spdif or I2S ?
Thanks, Patrick |
#43 | |
Hi Patrick You can use the Analog out~ Regards Huang |
#44 |
You can make like this~is not looks good,but it works good~
#45 |
And the digital out is SPDIF ?
How much do you want for postage to Hong Kong ? Patrick |
#46 | |
Hi Patrick Sorry I am not sure for the SPDIF,but i think it would be OK too. To Hongkong?not Germany?Total for one kit to Hongkong is 32USD~ Thanks~ |
#47 |
Digital out works too.
Built a little Toslink adapter Toshiba totx176. Just follow the connections in the datasheet. In every CD/DVD ROM there is two pins next to the analog audio output in the back. That is the spdif output but it is TTL level which I think is 5volts. Rather that risk frying my DAC, I Decided to use toslink which can take the 5V spdif fine. All you need is 5V power which is the same needed by the controller and one 8.2Kohm resistor. |
#48 | |
Thanks~ |
#49 |
A friend from HK will get in touch. Pls reserve one.
He might even pick it up from Shenzhen. Patrick |
#50 | |
OK~Thanks |
| CDROM Control kit with LCD display | slowgay | Vendor's Bazaar | 7 | 11th November 2010 01:44 AM |
| Great CDROM control KITs for sale | bbp | Swap Meet | 172 | 21st January 2010 01:04 PM |
| CDROM Control kit with LCD display | slowgay | Swap Meet | 3 | 30th December 2008 02:41 PM |
| CDRom Control Kit | fmak | Digital Source | 1 | 7th January 2007 08:32 PM |
| CDROM control kit | Lupulroz | Swap Meet | 35 | 13th August 2006 05:39 PM |
| Page generated in 0.11007 seconds (76.88% PHP - 23.12% MySQL) with 11 queries |
