Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 29th January 2009, 05:04 PM   #291
glt is offline glt  United States
Well, indeed you need four signals plus ground into OPUS (or any DAC), but I can only find 3 signals from the two CDROM I've hacked: BCLK, LRCLK and Data. No MCLK. But I also have the OPUS Metronome which is a asynch resampling and it does not take the MCLK because it generates its own clock.
If I try hard, I would probably find MCLK somewhere since there has to be a master clock in the CDROM otherwise it will not play music and the spdif output would not work
But I have not looked very hard for master clock since I don't need it.
In the two CDROMs I've hacked, the three signals I need are conveniently located in adjacent pins, so once I find one, the others are right there.
I also have a mini-oscilloscope (the one advertised in this forum for $50) and I can see these signals. The LRCLK is a steady 44.1 KHz square wave. The BCLK looks like a staircase sine wave (maybe because the scope has limited bandwidth since it is not steady) and Data is just data all over the place.
Old 29th January 2009, 05:24 PM   #292
Thanks qlt for clarification. Would the BCLK and SCLK be the same? I would think different manufacturers use different abbreviations, correct me if I'm wrong. Can I email you on this if I get further question? Appreciate it.
Fred
Old 29th January 2009, 05:59 PM   #293
Sure! Email me.
Old 30th January 2009, 03:04 PM   #294
acid_k2 is offline acid_k2  Italy
I've noticed the same wave (all but square wave!) in my cdrom, using a 20 Mhz CRT scope. It's a miracle that a DAC is able to use that.
Old 30th January 2009, 10:29 PM   #295
Hi qlt,
You're email is disabled.
Old 31st January 2009, 01:08 AM   #296
Originally posted by fredlock
Hi qlt,
I sent you an email. Don't know what is wrong I think I have the correct settings...
Old 2nd February 2009, 05:47 AM   #297
Default My second CDROM...
Almost done. This one is a bit more transparent :-)
http://picasaweb.google.com/lh/photo...eat=directlink
Old 2nd February 2009, 06:35 AM   #298
one might call it "naked truth"
BTW - how to get usable digital audio from a laptop (slimline) cd rom drive? All the desktop cd'roms I have used have quite well functioning digital (spdif) output.
I have a converter from 50 pin to 40 pin ide, but the only audio out is analog. Any hints?
Old 2nd February 2009, 12:03 PM   #299
@ audio-kraut
for digital output, you have to open your cdrom, and try to find spdif or I2S signals. Sometimes it's really difficult... start from analog outputs and trace that signals behind, You'll find the dac IC or a "all in one" IC. Try to find datasheet and then the digital signals pins...
Old 2nd February 2009, 06:27 PM   #300
I just opened a slimline CDROM. The controller chip is a Mitsubishi general purpose 16 bit microcomputer. I was able to find the datasheet and (obviously) the I/O pins are just described as generic I/O. Besides, the pitch size of the pins and components are even smaller. In theory, you can check each I/O pin and determine the BCK, LRCK and data lines with a scope. The Microprocessor has a built in DAC.
CDROM Control kit with LCD display slowgay Vendor's Bazaar 7 11th November 2010 01:44 AM
Great CDROM control KITs for sale bbp Swap Meet 172 21st January 2010 01:04 PM
CDROM Control kit with LCD display slowgay Swap Meet 3 30th December 2008 02:41 PM
CDRom Control Kit fmak Digital Source 1 7th January 2007 08:32 PM
CDROM control kit Lupulroz Swap Meet 35 13th August 2006 05:39 PM
Page generated in 0.12980 seconds (68.93% PHP - 31.07% MySQL) with 11 queries
