| Vendor's Bazaar Commercial Vendors large & small hawking their wares |
#21 |
Thanks Arjen, that's nice and clear.
Stupid Question Alert: Would I be able to run my Rotel 931 MKII Amp into your "25Watt TA2020 PCB new version fully finished and tested" amp; as people are raving about the sound quality of the Tripath TA2020? Or could I use the TA2020 as a preamp instead? Thanks again, Tony Swaine |
#22 |
...I've been thinking... that if I ran the TA2020 as a preamp, into the Rotel amp, I would lose any 'quality sound improvement' benefit, though, wouldn't I?
Tony |
#23 |
A pre-amp is basically a control unit that regulates the volume and allowes you to switch between input sources. An integrated amplifier consists of a built i pre amp and a power amplifier.
You could use the Rotel as a pre-amp if it has pre out exits. The TA 2020 which is a power amplifier should definitively not be used as a pre-amp. |
#24 |
Thanks, that's sorted that one out - I should forget the Rotel, and just run the source (CD) straight into the TA2020 and onto the speakers!
Thanks everyone for helping. Tony |
#25 |
Hi! In reply to Arjen and Morglo (posts #20 & #23): Arjen I am stunned and amazed at the power and quality of this tiny amp - the size of a fag packet!
I am running the amp (12V 2A DC supply) into 2x physically large 8 Ohm speakers, but without the pot, the volume was too high for comfort; but now it's exquisite! I have setup the "TA2020 PCB new version fully finished and tested" amp with a 100K volume pot and a 22k resistor on the output/GND (middle/2nd)/ (right/3rd) pins, as suggested here:http://sound.westhost.com/project01.htm This was to inprove the characteristics of the pot to enable a more Log Pot S curve response/sound. I have noticed a slight thump through the speakers, when I switch on the amp, but I am not at all concerned by this, as I have had this on a NAD 3020, and my current Rotel 931 mkII does the same thing. Is this a 'power surge'? I saw somewhere, of a configuration where someone had a resistor and a capacitor connected in-line just after the power in. What might that have been for? I cannot wait for the valve preamp TA 2020! Many thanks, Tony Swaine |
#26 |
Hi Arjen,
i'm the same guy who message u thru ebay. question, can i use one pcb for one speaker and ttherefore each one output 25w? is the new ta2020 model that u are launching soon, sonically better than the existing one? i am referring to the model that output 25w with 2 orange or res caps by the side. cheers....
#27 |
I'd also like to know the answer to adn6244's question.
As well as: If we have a pre-amp and want to bypass the pot on this board how do we do that? Just jumper the holes? Thanks, Matt. (kingmattman on ebay) |
#28 | |
Tony, I will be getting the same MKII Version of TA2020 and will be adding the volume pot. Any recommendation on how to do it on this board? gychang |
#29 |
Hi! This was sent me by Arjen:"To connect a volume potmeter you have to do the following:
- every stereo potmeter has 6 pins, in 2 rows of 3. every row of 3 is one channel, so one for left and one for right. the 2 last pins in each row can be connected to the ground wire from the PCB and from the source the middle pins can be connected to the TA2020 PCB input The 2 first pins can be connected to the source. if you have connected it it looks like this: [R-source][R-amp][GND] [R-source][L-amp][GND] then it should work! all these connectors should have there function written next to it " See the picture I've included, and orientate your pot in same way - ie turn it upside down with the pins sticking up, and the knurled knob facing you. (From my post to Arhen: I am running the amp (12V 2A DC supply) into 2x physically large 8 Ohm speakers, but without the pot, the volume was too high for comfort; but now it's exquisite! I have setup the "TA2020 PCB new version fully finished and tested" amp with a 100K volume pot and a 22k resistor on the output/GND (middle/2nd)/ (right/3rd) pins, as suggested here:http://sound.westhost.com/project01.htm This was to improve the characteristics of the pot to enable a more Log Pot S curve response/sound.") That is: 1. connect top left pin to right channel from cd output (or whatever source). 2. connect top middle pin to right channel connector R input on pcb board (or whatever source). 3. Top R pin on pot to ground (or earth) on the board. 4. Connect 22k resistor BETWEEN top middle and top R pins on pot. You place the pot between the output of your source (CD?) and the Input of the Tripath board. |
#30 |
Thanks for posting that, might end up doing it on my board.
Not sure coz I'm going to build a preamp though. |
| Ta2020 | Bengali | Class D | 0 | 29th September 2007 05:28 AM |
| What is the function of the V5A and V5D of TA2020 ? | xrcd24bit | Class D | 0 | 20th November 2006 06:32 AM |
| Eb-ta2020 | opentop | Class D | 16 | 30th May 2005 07:42 AM |
| Page generated in 0.10366 seconds (82.49% PHP - 17.51% MySQL) with 11 queries |
