| Vendor's Bazaar Commercial Vendors large & small hawking their wares |
#21 |
Hi
i'm interest to order ,how is the way ? ,i was sent you email about two days ago but not get a reply. can you tell me the difference of new SUN with the older version? and the MOON also thanks |
#22 |
I will reply every email,
It seem I have not received your email. When I received your email, my mailbox will send a reply email automatic, and I will send another reply in 24 hours. About SUN(version 2),We thought about some customers feedbacks , then we have in allusion to adjust the circuits and parts*, improve and made OPA-SUN (version 2), OPA-SUN (v2) had more humanity than original , but keep energetic, huge dynamics and good impulse response. Moon:This discrete opamp uses dual differential*gain stage and single ended output stage circuit design , we try and listen long term . The OPA-Moon sound characteristics is had a bit tubelike taste (vacuum valve) , soft and thick . |
#23 |
Rudiger,
Could you share more information on the distortion differences with the cascode. Any differences in bandwidth? Thanks, Jam |
#24 |
-3dB BW is around 8Mhz witout c, and *worse* with cascoding (5Mhz)
3rd and higher order harmonics rise at an order of magnitude, 2nd is the same (and dominating). all simulated.
"I can feel what's going on inside a piece of electronic equipment. I have a sense that I know what's going on inside the transistors." Robert Moog |
#25 |
oops..
but this one is an order of magnitude *better* EDIT: only with high freq (20k), 20Hz is still better without cascode! Just an simulation trick without any connection to the real world? Rüdiger
#26 |
Would these be a direct drop in replacement for an OP27 or 37? or are they dual only?
Fran |
#27 |
Rudiger,
Thanks. This is useful information. Jam |
| 990 discrete opamp | udip | Solid State | 18 | 12th February 2009 11:00 PM |
| My discrete opamp | udip | Solid State | 51 | 8th August 2006 07:33 AM |
| discrete opamp modules | biovizier | Parts | 6 | 2nd June 2005 03:29 PM |
| Page generated in 0.10318 seconds (71.02% PHP - 28.98% MySQL) with 11 queries |
