| Vendor's Bazaar Commercial Vendors large & small hawking their wares |
#211 |
is weight 1.5 kg.
the cuper ware is near 1 kg. the pair is 2 kg. This transformer may work in SE-SE variant and may have 3020+3020 = 6040 wounds in primary. The secondary may have 5856 wounds...
Shippment: $:Europe: 1,2 x (16+2,45 x Weight(kg)) N. Amerika & Asia: 1,2 x (10 +4,9 x Weight(kg)) |
#212 |
is the variant near keyboard and other for imging the dimentions...
You may conect the secondary sections across the coiles for kill inside negative cpasitanse. Here is a many variants conections, and you can use the trabsformer with a many tubes: Svetlana,Sovtek 6e5p, 6s45p,6s6p,6s30p...
#213 |
Thank you Ilja! |
#214 |
is
75-100-135 mm. The core have S = 10 sm2 The weight is 3.2 kg (each transformer). this transformer is in a hand. In nearest time I will make second transformer, make the photo and give you the instructions...
#215 |
a transformers before the painting...
But you will imegibe the dimention with a cap of Nescafe...
#216 |
email sent.
Ciao Guglielmo Italy |
#217 |
Hi there,
I intend to build the tube output stage below. I need a transformer in the schematic. Primary:230, secondaires: 2x120 and 2x6,3 (in case I go balanced and use 2 tubes instead of one) It would be best if you could wind it on a C core. I also need a choke 50mA/20H in place of R1 and R2. I’m also open to your suggestions as to use a transformer on the output instead of a cap. What would you recommend? Please quote price for one transformer on a C core 230 VAC primary, and 2x120VAC and 2x6,3VAC secondaries plus shipping to Ankara/Turkey And you can add additional cost of cap replacing transformer if you have a suggestion regarding that. I’d also appreciate any suggestion regarding a tube rectifier circuit for the schematic below. Thanks |
#218 |
E-Mail sent
#219 |
This trafo has re-made///
#220 |
Hi Nafanja (Ilja),
I'd be interested in your comments for Ersoy, as I built the lampizator circuit and you sent me the trafo (if you rememeber). I am particularly interested in the tube rectifier circuit (if you have a suggestion there), and the chokes that substitute the R1 resistor (take a look to the picture of Ersoy). It is possible that I will try the option you suggested time ago, i.e using 2 trafos for the output of my dac , instead of the caps that I have now. There is a picture you sent in this thread, showing the schematic .... Stay tunner, I might order from you the output trafos soon !! best regards, Pepe |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 05:23 PM |
| Help identifying a pair of output transformers and power transformers | mjk130 | Parts | 3 | 30th January 2009 10:44 AM |
| P-P Output transformers for sale | jazzbo | Swap Meet | 2 | 25th July 2008 08:39 PM |
| Page generated in 0.11296 seconds (77.31% PHP - 22.69% MySQL) with 11 queries |
