NP D1 DAC clone with enhancement NP D1 DAC clone with enhancement - Page 23 - diyAudio
Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 17th September 2012, 11:53 PM   #221
tenorsaxophone is offline tenorsaxophone  Italy
Originally Posted by woodturner-fran View Post
I did the upgrade - Spencer even supplied the parts needed to bring mine up from an older version. It has made a substantial improvement - the tonal balance is not what changes, what you get is improved resolution, more 3d soundstage, and cleaner tighter bass and treble. I've heard these kinds of improvements before and I put it down to ever decreasing jitter.
For the small outlay, and ease of installation, it's a no-brainer.
Fran
Hi Fran,
another question:
What of the 1-4 Output Mode Selection have you used in your DAC?
Just to make an idea for its setting.
Many thanks again for your help.
Regards.
Davide.
Old 25th September 2012, 01:12 PM   #222
samoloko is offline samoloko  Bulgaria
how about no deemphasis control
Old 26th September 2012, 07:18 AM   #223
many thanks for your gently answer.
But I meant the 1-4 Output Mode Selection of the "WM8804 to CS8412 converter board". Because I have to solder the resistor, I have before to choose the setting, and I have not understood the exact meaning of that setting.
I am thinking to solder the resistors on a kind of jumper in order to can change the settings.
Can you gently suggest what may be the best solution?
Thanks a lot.
Davide.
Old 6th December 2012, 08:48 AM   #224
Default 10KOhm potentiometer
I have purchased a good quality quad 10KOhm potentiometer for my amplifier.
I ask gently if D1V3 (D1V33 upgraded) can drive this pot with the original 10uF C4 C15 C25 C36 ?
Can I keep my (expensive) 10uF C4 C15 C25 C36 caps, or can the frequency responce be compromised?
Many thanks. Regards.
Davide.
Old 19th December 2012, 07:40 AM   #225
Default About WM8804 to CS8412 converter board again
Hi, excuse me for my misunderstanding.
Reading the .PFD guide, it seems (for me) that using the WM8804 to CS8412 converter board on D1V3 (D1V33 upgraded) it can works only at 16bit (mode 1 and 4 resistors combination).
If it is so, how can I choose between "Right-Justified Mode" and "I2S" selections?
I have not the Know-How to proceed the choise by myself.
Can you gently help me another time?
Many thanks. Best regards.
Davide.
Old 19th December 2012, 07:58 AM   #226
spencer is offline spencer  Singapore
Send a message via MSN to spencer NP D1 DAC clone with enhancement
I think the document has explained that clearly on page 1.
http://www.fetaudio.com/wp-content/u...-Details-3.pdf
Old 19th December 2012, 08:26 AM   #227
Hi Spencer,
I have already read it before!
But it is a description for all the possible combunation and usage. With a D1V3 DAC, can I use all the 4 output mode selection?
For D1V3 picture shows only 16 bit Right-Justified Mode. Is it the only selection mode that I can use?
If I had known this, I would not have posted the question, don't you think?
Davide.
Old 19th December 2012, 09:11 AM   #228
For SM5842, it can only do Right Justify mode (RJ) at 16 bit mode.
For PMD100, change all to Left Justify mode (LJ) for 16 to 24 bit mode.
On PMD100 converter board, cut trace pin 13 at bottom away from +Vcc and tie it to Ground at pin 14.
Old 25th January 2013, 04:41 PM   #229
Ok!
And about J28/J29 how have I set them?
With DIR9001 and SM5842 they had not effect to output mode. But now with WM8804 (RJ mode) and SM5842, have I to set J28/29 for 16 bit mode or not?
Thanks again.
davide
Old 25th January 2013, 05:52 PM   #230
Originally Posted by tenorsaxophone View Post
Ok!
Thanks again.
davide
again:
on my D1V3 board, J21 and J22 can switch between Dir9001 mode and 8412 mode (it is written just so); now with WM8804 how have I to set J21&J22??
Thanks again.
Davide.
NP D1 DAC clone with enhancementHide this!Advertise here!
Does anyone ever use enhancement-mode devices? keantoken Solid State 4 19th January 2009 09:52 AM
System Enhancement Help Victoria Subwoofers 1 12th January 2006 08:47 AM
Active Crossover And Sound Enhancement Units set Chip Amps 1 12th January 2005 10:32 AM
SubWoofer Enhancement Negative Design Analogue Source 0 31st December 2003 04:50 AM
Copyright ©1999-2017 diyAudio
