Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
NP D1 DAC clone with enhancement
Old 16th July 2012, 12:50 PM   #211
tenorsaxophone is offline tenorsaxophone  Italy
Originally Posted by spencer View Post
Hi Davide,
Shielding is to prevent oscillation due to some large film capacitor at about 180MHz. It will not help on sonic performance.
Spencer
Hi Spencer,
many thanks again for your help!
But how can I understand If capacitors that I use need to be shielded?
I am begin to test many type of capacitors in oder to find the best for sonic result with my amplifier and my loudspeakers system, and I'd like to know what of then need a shield.... How can I do?
Many thanks. Best regards.
Davide.
Old 16th July 2012, 02:03 PM   #212
spencer is offline spencer  Singapore
Send a message via MSN to spencer NP D1 DAC clone with enhancement
Unstable DC offset or hot jfets at output stage.
Old 23rd July 2012, 03:14 PM   #213
Note that there is an upgrade for this old DAC with WM8804 with better results. See below link:
D1V3 & D1V33 NEW upgrade – WM8804 to CS8412 converter board
Old 24th July 2012, 09:33 AM   #214
samoloko is offline samoloko  Bulgaria
how does WM8804 improve over CS8412 - better bass or what
did you measure jitter of two being on one location
can you play 24 /192 files when you use WM8804 on D1V33
Old 24th July 2012, 09:36 AM   #215
Note that SM5842 and PCM63 cannot take too high Fs and thus it should not work at 192k Fs.
Please read below document.
http://www.fetaudio.com/wp-content/u...l-Details1.pdf
Old 15th August 2012, 09:26 PM   #216
woodturner-fran is offline woodturner-fran  Ireland
HAving seen his post here, I emailed spencer to upgrade my D1 - which was actually an older D1V2 - but which had already been upgraded to take a DIR9001 and 5847.
Anyway, spencer very kindly sent on the new board with 8804 + the matched 2SK369 needed to bring the performance to near D1V33 specs. Cue a few weeks later and the parts arrive yesterday. Installing them was pretty easy because of the previous upgrades (the WM8804 slotted right in).
There is a clear sound improvement - improved clarity + bass is tighter, more defined soundstage - smaller details easier to notice etc. The replay chain is shigaclone>>D1>>LM3875 chipamp (audiosector premium kit)>>FHMK3 with Alpair 7s.Well worth the (small) outlay and the bit of desoldering etc to swap in the 2SK369.
The nice thing is that the extra detail etc is not at the expense of fluidity/midrange, and not a trace of sibilance or harshness. I had thought for a long while that my buffalo build edged out the D1, particularly since it had better midrange. Wouldn't be too sure about that anymore.
Happy camper!! Anyone with one of these DACs: its worth looking at this upgrade.
fran
Old 19th August 2012, 07:10 AM   #217
regal is offline regal  United States
This is great to hear, I am not surprised about your opinion on the Buffalo comparison. Thanks for the report. This Spencer's design had loads of potential, but really wasn't a "clone" at all, it has much more potential with the Jung style high quality power regulation and flexibility on the digital side. The nice thing about these "D1" boards is the ability to accept a masterclock , I wish I had held on to my SpencerD1 as it is setup for a good integration with iancanadas FIFO, if you are hearing an impact from just upgrading to the WM8804, this shows that there may even more opportunity with a large Ram Fifo. Spencer had really a quality design, I was "semi-happy" with the sk170 I/V sound but not enough to keep it, should have held on to it for the SK369 solution. Still kicking myself for that
Really do hope Spencer can get back into the multibit DAC design approach.
Old 14th September 2012, 09:15 AM   #218
D1V3 & D1V33 NEW upgrade WM8804 to CS8412 converter board
it could be very interesting!!
Now my D1V3 with all D1V33 upgrades and DIR9001 has reached a very good tonal balance with my amplifier and a very long selection of C4, C15, C25, C36 caps. Sound is very good and neutral.
Could it be possible that replacing DIR9001 with WM8804 the balancing of bass/high frequency can change? This should not be needed, because the amount of bass frequency is already good enough.
Can someone help me to decide?
Thanks a lot.
Davide.
Old 16th September 2012, 03:41 PM   #219
I did the upgrade - Spencer even supplied the parts needed to bring mine up from an older version. It has made a substantial improvement - the tonal balance is not what changes, what you get is improved resolution, more 3d soundstage, and cleaner tighter bass and treble. I've heard these kinds of improvements before and I put it down to ever decreasing jitter.
For the small outlay, and ease of installation, it's a no-brainer.
Fran
Old 17th September 2012, 12:03 AM   #220
Fran
Hi Fran,
many thaks for your important information.
I will do the upgrade as soon as possible!
Davide.
NP D1 DAC clone with enhancementHide this!Advertise here!
Does anyone ever use enhancement-mode devices? keantoken Solid State 4 19th January 2009 10:52 AM
System Enhancement Help Victoria Subwoofers 1 12th January 2006 09:47 AM
Active Crossover And Sound Enhancement Units set Chip Amps 1 12th January 2005 11:32 AM
SubWoofer Enhancement Negative Design Analogue Source 0 31st December 2003 05:50 AM
Copyright ©1999-2017 diyAudio
