Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
NP D1 DAC clone with enhancement
Old 28th June 2009, 04:44 AM   #141
spencer is offline spencer  Singapore
Send a message via MSN to spencer NP D1 DAC clone with enhancement
All,
D1V33 with PCM1704U converter board is completed.
Note that PCM1704 is better resolution than PCM63. To rate them subjectively, 1704 is higher resolution while PCM63 is more musical. Both DAC chip sound very good.
Old 29th June 2009, 07:06 AM   #142
I did not forget all the D1V3 users here and thus I offer an upgrade of the Jfet IV (attached) but I only provide the critical parts (K369BL x 8, Resistors x 8 and VR 100 ohm x 4). The cost is $13 include shipping to worldwide.
The upgrade improve the D1V3 by about few points but I would say it is a better upgrade from PCM63P-K to PCM63P-K2, KY or Y.
Old 29th June 2009, 06:11 PM   #143
Kamel is offline Kamel  Germany
Send a message via ICQ to Kamel
Hi Spencer,
can you provide me a PMD100 Board + Chip.
I wanna play with PMD and SM5842.
Best regards
Felix
Old 1st July 2009, 09:02 AM   #144
pinial26 is offline pinial26  France
hello
have you got a BOM with price for D1V33 with PCM1704U converter board ?
regards
Old 1st July 2009, 11:19 AM   #145
pinial26,
I only provide PCM63PK chips at this moment.
The converter board I use is designed for PCM1702. For Pcm1704, the digital supply +ve and -ve pin must be reverse connection and thus I need to cut trace and solder two wires at the bottom. So there is no PCM1704 converter board available from me yet and I cannot offer any price.
Regards, Spencer
Old 14th July 2009, 02:54 PM   #146
breizheau is offline breizheau  France
Is there any dedicated thread about the building of this DAC ?
I have problems to get the 8.5Vdc for 2 ways at the step 19....
Old 14th July 2009, 03:13 PM   #147
here is the thread: klick
Best regards
Felix
Old 14th July 2009, 03:29 PM   #148
Thx Felix.
Old 14th July 2009, 09:42 PM   #149
elviukai is offline elviukai
elviukai's Avatar
hello Spencer , its about half year passed untill today i finaly started solder both dv3 dac's , and find just now that new version is available.
I forget one thing, if your new pcb have more space, I am not able to put in any more seriuos metalized 0,1uf fil cap. wima MKS will fit but smallest wima MKP will not fir in with in pcb are only 2mm and wima MKP is 3-4mm (pcb pi spacing is 5mm and OK , height not important)
I think I may order one extra kit to compare.
natural sound reproduction from traditional dynamic drivers?!! come on.. no no, it can be.. it must be!..
Old 15th July 2009, 12:56 AM   #150
The D1V3 and D1V33 pcb are same size, same mounting hole position, same connector position and use same size parts for the 0.1uF film cap, ie 5mm pitch and size3x8mm. If you have a bigger size film cap, some of the location near the jfet IV section may not be fitted. For bigger size cap, you have to solder on the bottom!
In D1V33, I change to Panasonic 0.047u 50V ECQ-V or ECQ-B (old version but bigger size) and I find most of the locations can be fitted.
MKP is more expensive and may be better for signal coupling but I think MKS or mylar cap is ok for supply decouple.
You can PM me if you are interested in the new version. Thanks.
NP D1 DAC clone with enhancementHide this!Advertise here!
Does anyone ever use enhancement-mode devices? keantoken Solid State 4 19th January 2009 09:52 AM
System Enhancement Help Victoria Subwoofers 1 12th January 2006 08:47 AM
Active Crossover And Sound Enhancement Units set Chip Amps 1 12th January 2005 10:32 AM
SubWoofer Enhancement Negative Design Analogue Source 0 31st December 2003 04:50 AM
