Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
The news D-Amp DLS3000....
Old 22nd May 2007, 11:10 AM   #201
solarian is offline solarian  Hungary
and what about the PKN Control's XE Amplifiers, Gyula ?
Its already from Hungary
Old 22nd May 2007, 12:20 PM   #202
Gyula is offline Gyula  Hungary
Gyula's Avatar
Send a message via Yahoo to Gyula
Probably, If your amplifiers are full as good as D-amp. The 1U form factor seems to be OK!
Old 22nd May 2007, 01:29 PM   #203
fredos is offline fredos  Canada
Look good, inside look as a power soft! What about the use under 120V?
Old 15th May 2009, 01:06 PM   #204
1triphet is offline 1triphet  Thailand
Send a message via ICQ to 1triphet Send a message via AIM to 1triphet Send a message via MSN to 1triphet Send a message via Yahoo to 1triphet
Default XM-D1000P5
Old 30th August 2009, 04:04 PM   #205
DETED AUDIO is offline DETED AUDIO  Thailand
Send a message via AIM to DETED AUDIO Send a message via MSN to DETED AUDIO Send a message via Yahoo to DETED AUDIO The news D-Amp DLS3000....
Originally Posted by 1triphet View Post
For All SONY XM-D1000P5 .hehehe
Old 31st January 2010, 05:08 PM   #206
Workhorse is offline Workhorse
Workhorse's Avatar
Originally Posted by km View Post
Be serious, don't make us laugh (well, make us laugh if you want )
What the pictures show, rated in standard terms, is a 2x300W rms into 8 ohm and 2x500W rms into 4 ohm amplifier.
dont you think a high power amp for proaudio use should have this?
best rgds - karsten madsen - cadaudio.dk / digiamps.com
Mr. MAD alll you can do is just laugh on others, well lets laugh on you now, because time has came for others to laugh on you
Old 27th January 2017, 09:20 AM   #207
stewin is offline stewin  Kenya
Originally Posted by fredos View Post
Here some pick of our news prototype of the D-Amp DLS3000...It's a 1000W RMS per ch/4 ohms and 1500W RMS per ch/s ohms in class B-D, powered by a pair of STW50NB20 at +/- 92V by an IGBT heat sink less switching power supply. Full power measured for 15 min, 8 hours burn-in at 1/3 of maximum power. Sound is very nice. Some cue about the amp...Hight side of the drivers is powered by NE555 charge pump, 0-100% duty cycle, current sens only on the negative side, power limited in 2 ohms by an NSL32 optocoupler in the feedback loop, reduce distortion in 2 ohms and improve stability, first time I try this, and it sound very nice! Clipping limiter by JFET j112 into error amp, work very well and very fast too!
I will talk to you soon about news prototype of combinated amplifier and switching power supply in phase modulation, heat sink less for about 2 Kw per ch...seem to work well now, but some little thing to fix...
Have a nice views!
Kameleon group
hi fredos how is your amp doing . nowadays there are better fets for class d amps
The news D-Amp DLS3000....Hide this!Advertise here!
There's good news and there's bad news Magnetmaz The Lounge 14 2nd January 2012 06:39 AM
