Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Modulus-686: 380W (4Ω); 220W (8Ω) Balanced Composite Power Amp with extremely low THD
Old 13th June 2018, 01:03 PM   #511
daansan is offline daansan
I am using mogami xlt interconnects. Are you also using canare (or something similar) inside the ampís chassis?
Old 13th June 2018, 01:20 PM   #512
misterdog is offline misterdog  United Kingdom
Van Damme starquad core in and out here.
Seems to have less capacitance than Canare starquad. Van Damme - Specifications - Tour Grade Classic XKE Starquad microphone cable
Some silver plated strands thrown in too.
Old 14th June 2018, 04:33 PM   #513
sq225917 is offline sq225917  United Kingdom
Send a message via MSN to sq225917 Modulus-686: 380W (4Ω); 220W (8Ω) Balanced Composite Power Amp with extremely low THD
Sorry to hear about your dad passing Tom, best wishes to you and family.
Paradise Pre-reg PSU PCBs
Old 14th June 2018, 05:07 PM   #514
454Casull is offline 454Casull  Canada
Sorry about your dad. RIP and best wishes.
Old 16th June 2018, 04:56 AM   #515
HarmonicTHD is offline HarmonicTHD  Switzerland
Yes. What can I say Tom. All the best and my condolences to you and your family.
Best regards
SH
Old 22nd June 2018, 12:53 AM   #516
atltx is offline atltx  United States
Default Condolences
Wanted to express condolences to you after your father's passing. May he rest in peace.
Old 25th June 2018, 06:36 AM   #517
tomchr is offline tomchr  Canada
tomchr's Avatar
Thank you for all of your condolences. I really appreciate it.
I'm getting back to something that resembles normal.
Tom
Modulus-686: 240W/8Ω @ <0.00025% THD. Modulus-86: 40W/8Ω @ 0.000054% THD. DG300B & Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 25th June 2018, 11:00 AM   #518
Tom,
I'm about to start populating the ISS board, but I cannot find the detailed component mapping in the ISS docs.
The Mouser project lists all the components but does not list where to mount them (R7, R7, etc..)
Am I missing something?
Thanks,
Daan
Old 25th June 2018, 11:55 AM   #519
Another question is regarding the connection from the ISS to my 4 meanwell RPS-400-36 PSU's..
The ISS documentation states to either configure for 115v or 230v.
I am assuming this configuration has to do with connecting the ISS to transformers as they typically need the primary wired in series
If I omit the wire bridge for 230v, am I correct in assuming that the output of the ISS will have two 230 VAC outputs (J8 --> AC | 0 | 0 | AC)?
Or do I also need the bridge for 230VAC above J8 when using the Meanwell SMPS's?
Old 25th June 2018, 12:44 PM   #520
tomchr's Avatar
Argh!! It looks like I forgot to include the BOM in the design doc. I'll fix that when I get home. I travel on July 3rd, so expect the doc to have been fixed by July 4th or 5th. Sorry for the omission.
Yes. The BOM...
Configure the board for your local mains voltage. Then hook the Mean Well supplies to the two AC terminals (terminal 1 and 4). I forget which is the live and which is neutral. You can easily trace the neutral on the board. If I recall correctly, terminal 4 (oval pad) is the Neutral and terminal 1 (rectangular pad) is the Live.
I should add that to the doc as well.
Tom
Modulus-686: 380W (4&#937;); 220W (8&#937;) Balanced Composite Power Amp with extremely low THDHide this!Advertise here!
Modulus-86: Composite amplifier achieving <0.0004 % THD+N. tomchr Vendor's Bazaar 2405 13th September 2017 06:10 AM
SDTRANS384, MODULUS-86, POWER SUPPLU AND TROIDALS, Audio nirvana 8 alnico potstip Swap Meet 14 14th August 2015 01:06 PM
cabiant for Xpload 220w Hosam Subwoofers 19 12th March 2011 04:37 AM
Extremely low power and low loss transformers percy Tubes / Valves 12 23rd February 2005 10:30 AM
Extremely low power first amp problem m0rg Tubes / Valves 9 16th February 2004 11:05 PM
