Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 30th November 2017, 03:24 PM   #21
cps3113 is offline cps3113  Ukraine
I'm interested in the 1 pc Dual boards pcb.
Please PM for procedure.
thanks
Old 14th December 2017, 01:11 PM   #22
bestb4 is offline bestb4  Estonia
Can I just get the PCB and the 3pcs of LT3045?
Old 16th December 2017, 08:32 PM   #23
Stammheim is offline Stammheim  Germany
Hi guys,
The best way to contact me is to pm, so sorry I let you guys waiting. I just wrote you, so if you still are interested in some boards, just let me know.
I really like the HFE diodes, but because the guys are getting hot to above 90C° when delivering 3A, I recommend good quality Vishay MBR1045 instead, which have nearly half Vf and got comfortable warm. I always let it people know within the HowTo, but want to make the hint "official" here.
I you have questions, let me know.
There are people around the world using the LT3045 boards, I'd be happy about people sharing their experiences here, so feel free
Stammheim
Old 13th January 2018, 12:28 PM   #24
Cornan is offline Cornan  Sweden
Cornan's Avatar
Hi @Stammheim!
I tried the first of my two single ps boards today. Here is my initial impressions I just posted in my CA thread.
The true experimental tweak thread - Page 150 - Networking, Networked Audio, and Streaming - Computer Audiophile
Thanks a lot for a brilliant product!
Best regards,
Micael
Old 14th January 2018, 12:41 PM   #25
aakkonen is offline aakkonen  Finland
Hi Stammheim! You asked me some time ago to post about my project. Here is what I did with the superb PSU. I love the look of the blue heat sinks which are visible through the venting openings on the top!
More information in the DAC thread: Dual mono AK4495S with AK4137 and MCU/LCD DAC kit for $160 and more photos on my website.
Old 14th January 2018, 01:18 PM   #26
Cornan's Avatar
Very nice build @aakkonen! I will get my single ps's boxes later on and surely want something that shows the beauty of Stammheim's boards. I love when beauty in looks meets beauty in SQ.
Old 29th January 2018, 03:07 PM   #27
SDW1 is offline SDW1  Belgium
Hello
I am new to this forum.
Do you have more naked boards available?
And if so, what is shipping cost to Belgium?
Greetings
SDW1
Old 29th January 2018, 09:05 PM   #28
Sligolad is offline Sligolad  Ireland
Installed the 6 x LT3045 Power supply in my audio PC last week.
Audio PC - Gigabyte H97M-D3H & PPA OCXO Mobo, Intel Core i7 4770S • 1150 Haswell, Crucial Ballistix Sport 16GB Kit (8GBx2) UDIMM Memory Modules BLS2K8G3D1609ES2LX0 DDR3 PC3-12800 • 9-9-9-24 • set at 5-5-5-20 • Unbuffered • NON-ECC • DDR3-1600 • 1.35V • 1024Meg x 64 • Low Profile, Bios set 800mhz Cpu & Memory, Teradak ATX Linear for 20 pin ATX on Mobo, Paul Hynes SR7EHD 12v for Mobo, 5v for clock.
It has provided a great step up in the sound, better bass attack cleaner transients.
Got the boards built with both channels combined to power the Motherboard RAM at 1.3 volts.
Startup amps for RAM are at 2.9 amps and quickly settles at 2.7 amps.
When I first set it up i supplied 5v in from a Paul Hynes power supply and the heatsink was getting too hot so switched to 3.3v in off 2 x Lipo4 batteries trickle charged off a 3.3v linear supply and now running at a nice temperature.
Really impressed with this Power Supply so ordered a second unit.
Old 30th January 2018, 12:08 PM   #29
Cornan's Avatar
Nice!
Here is another thing you might want to try out when you get your second single ps?
I have tried it out using a Gophert csp-3205II (floating lab SMPS) powering my Brooklyn DAC with awesome results in terms of SQ.
Three power supplies in series is surely over the top. However, the SQ jump is unquestionable in my setup and it could hopefully give you or anyone else food for thoughts!
Old 10th February 2018, 05:17 PM   #30
Shutdown98 is offline Shutdown98  Netherlands
Forgive the noob questions... but is it no problem to feed the second ps a dc voltage? (apparently not).
How do you set the voltage of the "first" and second PS if for example 12Vdc is the final output?
What happens to the max load in Ampere when put in series?
Daphile - PC streamer - JCat Femto > WaveiO usb to I2S > Soekris dual mono DAM 1121-01 > Bryston B60 sst > Discovery 4
low noise Pre-Amp / DAC power supply MJE15034 TL072 Regulator based on STUDER 900 yoshisoakland Power Supplies 13 11th June 2018 04:29 AM
FS: TPS7A4700 low noise power supply SALE!!!!! mravlca Vendor's Bazaar 8 18th March 2017 08:46 PM
Ultra Low Noise and Low Power Consumption OCXO ULNOCXO Vendor's Bazaar 21 6th July 2014 09:39 PM
Ultra Low Noise - Ultra Low Impedance - Ultra big Problems! Stefan0815 Analog Line Level 2 14th January 2014 06:01 AM
Scavenging ultra low noise power supply jackinnj Power Supplies 3 7th September 2008 04:32 PM
