Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 21st June 2018, 08:48 PM   #261
Cornan is offline Cornan  Sweden
Cornan's Avatar
Originally Posted by Cornan View Post
That’s it? No reasons why common mode chokes are better than balanced transformers?
Edit! BTW. I am NOT trying to trap you into
a corner. Not my style. I am just trying to get the things straight!
Those are my principles, and if you don't like them...well, I have others.
Graucho Marx
Old 22nd June 2018, 06:41 AM   #262
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
What is balanced in this context? Picture?
/Per-Anders (my first name) or P-A as my friends call me
Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 69 pcb's in order. 69 paid.
Old 22nd June 2018, 07:11 AM   #263
Cornan's Avatar
Here is a picture of my feeder supply for my dual LS-HPULN which are connected to a balanced isolation transformer.
Graucho Marx
Old 22nd June 2018, 07:17 AM   #264
Cornan's Avatar
Here is an internal picture of my feeder supply for my dual LS-HPULN which is connected to a balanced isolation transformer.
Graucho Marx
Old 23rd June 2018, 03:14 PM   #265
sq225917 is offline sq225917  United Kingdom
Send a message via MSN to sq225917
There's no point me repeatedly stating my opinion. You appear to be trying to make it a binary choice of one being better than the other, which simply isn't the case. If you have common mode noise across the AC then a common mode choke is an ideal way to remove it. If you have another issue with your mains, perhaps DC, then a DC filter/trap is the way to go, likewise other situations may exist where a balanced transformer is beneficial.
However I'm looking to power my Brooklyn which needs only a single DC rail and I have no DC on my mains, so...
Paradise Pre-reg PSU PCBs
Old 23rd June 2018, 03:16 PM   #266
SO you have a transformer with a centre tapped secondary earth at 0V and that feeds the AC input of another?
Old 23rd June 2018, 03:31 PM   #267
Cornan's Avatar
No, I am not trying to say that a balanced transformer is better than a common mode choke. Sorry if it came out that way! I am interested to know why a choke is better since in theory a balanced transformer cancel out common mode noise by design? Reality may not be the case but it surely sounds better than any other thing that I have tried. I’m just curious if a common mode choke would be beneficial on a balanced transformer?
Graucho Marx
Old 23rd June 2018, 03:33 PM   #268
Cornan's Avatar
Yes, plus a DC blocker trap filter pre the balanced IT.
Graucho Marx
Old 25th June 2018, 05:28 PM   #269
peranders's Avatar
Just wondering, what is the advantage of a balanced 230 VAC compared to a non-balanced except for "it sounds better"? Any measurements which proves a point?
Old 25th June 2018, 05:42 PM   #270
Cornan's Avatar
Sorry, but no! I only use my own ears for evaluations. I own four different IT’s and find the balanced one (with IEC input connected to the Schuko output via chassi ground and bypassing the transformer) better by quite a lot than the other three IT’s in my setup. The balanced snd floating 230-12VAC toroidal transformer concured my flaoting SMPS as a feeder supply for dual 5A LT3045 (LS-HPULN) powering Brooklyn DAC. However, not a huge difference in SQ terms according to these ears!
Graucho Marx
low noise Pre-Amp / DAC power supply MJE15034 TL072 Regulator based on STUDER 900 yoshisoakland Power Supplies 13 11th June 2018 04:29 AM
FS: TPS7A4700 low noise power supply SALE!!!!! mravlca Vendor's Bazaar 8 18th March 2017 08:46 PM
Ultra Low Noise and Low Power Consumption OCXO ULNOCXO Vendor's Bazaar 21 6th July 2014 09:39 PM
Ultra Low Noise - Ultra Low Impedance - Ultra big Problems! Stefan0815 Analog Line Level 2 14th January 2014 06:01 AM
Scavenging ultra low noise power supply jackinnj Power Supplies 3 7th September 2008 04:32 PM
