Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
AZ OLED setup kits for Soekris dam1021/1121 control
Old 14th May 2018, 12:32 PM   #421
audiozen is offline audiozen
Originally Posted by gavinb View Post
Leon,
Thanks,
How do you toggle between programming boards? There are 2 DB9 connectors?
You can connect the board directly with the USB and TTL interfaces. Update Firmware one by one.
Old 14th May 2018, 05:50 PM   #422
kikiwillybee is offline kikiwillybee  France
Hi
Please Mr LEON, can i use also DAM 1121 Dac Card ?, with or without adaptations ?,
For use I2S Port, please how removed the 3 33ohm resistors,
Can i use Amanero'17 Xo1 CRISTEK 957 USB card, or ARMATURE-SINGXER F1 usb card,
or ur good advices for high grade USB Card ?....
yours,
thanx,
w :-)
Old 16th May 2018, 04:29 AM   #423
mimao is offline mimao  Poland
Originally Posted by audiozen View Post
We used the isolated serial and i2s.
Attachment 679156
My proposal on design phase:
PLS do transformer/PSU part easy to broke apart as somebody may use own PSU or want to shift it in lengh if has case which is not enough wide.
Old 16th May 2018, 07:01 AM   #424
All standard I2S Interface USB cards can be used.
If you need to use 2 I2S interfaces, you need to remove several resistors of 33 ohms(nearby the I2S interface, note 33*3
), so that HDMI can not be used.
Originally Posted by kikiwillybee View Post
Hi
yours,
thanx,
w :-)
Old 16th May 2018, 07:09 AM   #425
This is just a test version. The final version should be divided into 2 parts, PSU and DAC, otherwise the PCB size is too large. And the DAC part maybe use 4 layers of PCB.
Old 16th May 2018, 05:11 PM   #426
sfox7076 is offline sfox7076  United States
I upgraded the firmware and now I cannot get signal to lock. Light on board stays solid when I send signal to usb board, but no output from the dac and LCD says "unlock".
Old 16th May 2018, 05:22 PM   #427
spikestabber is offline spikestabber  Canada
Remember to run update in uManager to upgrade the firmware of the micro.
Soekris dam1021-12v2 dual-mono balanced: https://imgur.com/a/fD68M Update: https://imgur.com/gIn6Nkx
Hypex nc400: https://imgur.com/iORCyna | Overkill TT2USB: https://imgur.com/a/p6OiS
Old 16th May 2018, 05:59 PM   #428
Figured it out. Somehow the connection speed was changed. Resetting it to 115200 had me back in business.
Old 18th May 2018, 05:42 PM   #429
passive420 is offline passive420  United Kingdom
One more SK board up and running, we have power at least.
The LED beside the DC input on the DAM1021 is blinking furiously, I'm sure I have seen mention of this but cannot find it... can someone enlighten me?
Old 18th May 2018, 07:28 PM   #430
fred sonnen is offline fred sonnen  Germany
Hallo Audiozen
I bought a sk lite.
This week te case for all the items came.
I my case the Rotary encoder cable is a little bit short ;-). I can use it but I have to route it over a 100VA Transformer. Will this be a problem?
The cable for the IR receiving tube is to short. Is it allowed to lengthen the cable?
Or do I need a new cable? What is the max. lenght? How do you call the 3pin connector?
Thr OLED flat cable is long enough ;-) But I have to route it over the 100VA Transformer, too. Will this be a problem?
Greetings
AZ OLED setup kits for Soekris dam1021/1121 controlHide this!Advertise here!
Linux servers and Soekris DAM1021 robertrowett Digital Line Level 141 26th February 2017 09:33 PM
WTB: Soekris dam1021 kcdonahue Swap Meet 1 2nd October 2016 03:43 AM
WTB Soekris dam1021-02 guglielmope Swap Meet 4 3rd December 2015 08:42 PM
FS - Soekris dam1021-02 jeremysk Swap Meet 9 16th October 2015 12:17 AM
For Sale-Soekris dam1021-05 stonehome Swap Meet 3 19th July 2015 02:38 PM
