Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Volt+ tpa3118 testing data
Old 17th March 2017, 01:48 PM   #11
cdsgames is offline cdsgames  Canada
Originally Posted by alkasar View Post
rise also present on the 8ohm measurements.
+1dB at 20kHz is not a big deal. It seems to indicate that the output filter has an overshoot.
Is the detailed schematic with component values availbale ?
I will ask the team to detail the filter values , for Monday
Old 17th March 2017, 04:16 PM   #12
I will ask for 8 Ohm 1W to compare.
Old 17th March 2017, 08:18 PM   #13
doctormord is offline doctormord  Germany
doctormord's Avatar
Originally Posted by cdsgames View Post
Yes we measured first at 4ohm but there is not much diff at 8ohm. We used our own SMPS at 19v better than most SMPS but still some noise on it.
Yes gain is lowest 20db and yes I think we reach (and few cases exceed) the EVM.
I hope the measurements show that our Volt+ is a well designed TPA3118.
I thought your Volt+ is "immune" to power-supply-noise"?
So in the end we are getting the performance expected from the EVM, okay. Question is, will the performance be at the same level when skipping the cap. multiplier?
Old 17th March 2017, 09:11 PM   #14
hajj is offline hajj  Lebanon
hajj's Avatar
Isn't it kind of a moot question since the Volt+ comes with a built-in cap multiplier?
Nick
Old 17th March 2017, 11:10 PM   #15
doctormord's Avatar
Of course.
Old 18th March 2017, 08:58 AM   #16
Actually , if you look closely , we beat the EVM .
I think there fair question is...can any modded board come even close to our test figures ?
Old 18th March 2017, 09:18 AM   #17
doctormord's Avatar
If i look closely, i see that you measurements are done at 20dB gain while all datasheet plots are for 26dB. So it's not comparable.
Old 18th March 2017, 12:12 PM   #18
alkasar is offline alkasar  France
why do that ? it is onboard. if it improve performance, it's a good idea.
EVM data is not published at 20dB gain. How can one be so sure results are better than the published data ? Pointless discussion without the data.
It's fair to reckon that this commercially available board has the best published measurements, without any mod. Even when compared to other cheap boards modded by diyers I have seen on this forum.
It is available for sale, for a fraction of the EVM price. That's good news for the byers.
Old 18th March 2017, 12:31 PM   #19
doctormord's Avatar
To see the performance impact.
Old 18th March 2017, 12:35 PM   #20
irribeo is offline irribeo  Netherlands
It has been measured to have 800-8kHz frequency respons, it was the best then too. At the moment the respons deviation might seem unimportant, but it points to either componentvalues being off more than 50% or still wrong measurement setup. From this measurement setup it is the best, nobody else measured like this. Or boards produced contain components more than 50% off, buy buy buy???
Volt+ tpa3118 testing dataHide this!Advertise here!
DD-Z2 wanting to run this amp at 16 volt and charging 17.5-18 volt is it capable? Bills amps Car Audio 3 14th September 2015 12:49 PM
12 volt to 300 volt inverter question for tubes yourownfree Tubes / Valves 93 30th March 2014 04:41 PM
Testing a transformer without a data sheet bramofon Everything Else 7 20th April 2013 06:00 PM
New testing data ucla88 Multi-Way 7 5th June 2008 01:58 AM
