Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Volt+ tpa3118 testing data
Old 23rd November 2017, 12:12 PM   #91
gnat_leader is offline gnat_leader  Brazil
Default Volt+ D amp board size?
Originally Posted by cdsgames View Post
Waiting on a new PCB, will update once we test
When this Volt+D amp comes out, I assume it will be for sale with and without a case... the same case as used in the current Volt+ w/stepped attenuator? Meaning, could I buy the new amp board and swap it with the board in the amp currently for sale?
Old 23rd December 2017, 02:17 PM   #92
ernperkins is offline ernperkins  United States
ernperkins's Avatar
Any new updates?
Old 25th December 2017, 08:43 AM   #93
cdsgames is offline cdsgames  Canada
This week we will start testing the new PCB.
Old 25th December 2017, 03:41 PM   #94
Octavia is offline Octavia  United States
Merry Christmas and Happy PCB testing
Old 28th December 2017, 02:29 PM   #95
Size is not the same. We use much bigger inductor and there are 2x tpa3118 ICs
Old 12th January 2018, 03:10 PM   #96
Default Volt+ D v1.3
BOOM.
Ladies and gents , Volt+ D (ouble) was received.
All capacitors in the analog path are film ()
We hooked up the Volt direct to speakers......testing team apparently started to dance (while normal in Bollywood movies I assure you it never happens in reality)
OK..OK I know its not a objective test.
I am happy to announce that Volt+ D revision 1.3 PCB is singing .
Next week... AP testing .
Old 13th January 2018, 02:52 PM   #97
Doctor J is offline Doctor J  United States
BOOM.
Damn, that looks beautiful. Any idea when it will become available in the US?
Old 13th January 2018, 05:23 PM   #98
So finally an amp to open your inner Bollywood dance moves! Can I sign up for four Ginger Rogers mono blocks with stepped attenuators?
Old 13th January 2018, 07:31 PM   #99
doctormord is offline doctormord  Germany
doctormord's Avatar
I suspect the most improvements in THD are related to these bigger and low distorting inductors as we've shown in the past.
Any plans to swap TPA3118 for the newer TPA3128 as this improves output impedance and burst ratio?
Old 14th January 2018, 01:56 PM   #100
zek is online now zek
zek's Avatar
Or TPA3156D2?
Volt+ tpa3118 testing dataHide this!Advertise here!
DD-Z2 wanting to run this amp at 16 volt and charging 17.5-18 volt is it capable? Bills amps Car Audio 3 14th September 2015 11:49 AM
12 volt to 300 volt inverter question for tubes yourownfree Tubes / Valves 93 30th March 2014 03:41 PM
Testing a transformer without a data sheet bramofon Everything Else 7 20th April 2013 05:00 PM
New testing data ucla88 Multi-Way 7 5th June 2008 12:58 AM
