Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Isolator board for RPI/ i2s/ i2c
Old 11th July 2017, 09:03 PM   #61
jonners is offline jonners  United Kingdom
jonners's Avatar
Originally Posted by DJ le Roi View Post
Jonners wrote: Have you tried powering the Kali to see if it will feed power to the Isolator, with the 'feed sbc' jumper closed? I have the iancanada isolator and it works like that, whereas power fed to the isolator does not pass through to the Kali and DAC.
I did it, and yes, it works! So you can use the Isolator and the Kali together. Feed the Kali. Close the feed sbc jumper. The Kali will feed the Isolator.
I hope you're supplying 5V to Kali, not 6.4V from the batteries?
Since it works, I guess you must now be bypassing the regulator in the isolator which steps down from 6V+ to 5V.
Old 12th July 2017, 11:57 AM   #62
cdsgames is offline cdsgames  Canada
Yes I can confirm that our team did implement it (I was not aware)
So our isolator is capable of sourcing 5V from above stage (Kali Dac etc) then regulate it down for clean side isolation IC.
Old 14th July 2017, 07:44 PM   #63
Skip Pack is offline Skip Pack  United States
I want to be very sure I'm powering my newly arrived Isolator correctly. Is there a difference other than connectors between the power jack input and the battery input pins. I expect to use either batteries or a supply with greater than 5 volts and want it to power the Isolator board and the Boss DAC. I'll leave my current linear supply on the RPi2.
Skip
Old 16th July 2017, 11:50 AM   #64
No difference between the 2.
On the barrel make sure middle pin is positive . I myself use it with 4 batteries . (2 serial 2 parallel about 6.6v output)
Old 17th July 2017, 10:22 AM   #65
DJ le Roi is offline DJ le Roi
@cdsgames
I understand the Kali needs an independent PSU. Is it somehow possible to modify the Kali so that I can feed the Isolator/Kali/Piano combination with two LifePo4 batteries PSU (6,6V)?
Old 17th July 2017, 07:05 PM   #66
No need to modify...just use 5V on Kali and set the jumper to (feed sbc)...that in turn will feed the isolator (5v its enough) and the stage above
You cannot modify the LDOs whiteout some serious work (to have them work at more than 5.5v)
Old 17th July 2017, 07:22 PM   #67
Originally Posted by cdsgames View Post
No need to modify...just use 5V on Kali and set the jumper to (feed sbc)...that in turn will feed the isolator (5v its enough) and the stage above)
Yes I know, but I wanted to use a LifePo4 PSU for the Isolator/Kali/Piano 2.1....
Old 18th July 2017, 02:05 PM   #68
Not possible with current LDOs...max is 5.5V
Old 19th July 2017, 10:02 AM   #69
DJ , if you remove a diode on Kali, you will be able to feed from below.So basically using your Isolator (at 6.6V as requested)
Can you use a soldering gun ?
Old 19th July 2017, 11:34 AM   #70
Yes, I can.
Isolator board for RPI/ i2s/ i2cHide this!Advertise here!
Troubleshooting RPi/Moode -> Buffalo II I2S: only distorted sound on one channel jonwhitear Digital Line Level 7 1st November 2016 01:57 PM
RPi 2 with PiFi DAC+ and TDA7297 board noonereallycares PC Based 9 6th October 2016 06:47 PM
[diy] Another USB to multichannel I2S with I2C ? egberttheone PC Based 2 17th August 2013 09:53 AM
I2S vs I2C problem please help! microneeds Digital Source 6 19th October 2012 09:50 PM
I2C/I2S,what's the difference??? Leolabs Parts 2 18th April 2005 01:20 PM
Copyright ©1999-2017 diyAudio
