Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
New DAC for RPI with subwoofer out (2.1 or 2.2)
Old 5th August 2016, 11:16 AM   #1
cdsgames is offline cdsgames  Canada
Default New DAC for RPI with subwoofer out (2.1 or 2.2)
We have designed a new DAC working with any SBC/RPI (i2s)
We are using 2 DAC ics PCM5142 with integrated DSP. The PurePath software from TI is available for download (registration required) and can be used to create specific filters and other audio functions.
The board will come pre programed as a 2.1 output (but you can create your own custom design and load it the board and can access the xover frequency directly from linux (we made a small app)
Hardware wise , we have split the digital and analog side with LDOs and we feed the analog side using an extremely capable (low noise ultrahigh psrr) LT3042. Basically each board has 4 LDO (2 for each DAC ic) (note that digital side uses cheaper LDOs)
Of course , on the analog side we used only thin film resistors and poly caps in audiopath.
This DAC has RCA outputs but also a small connector that will connect to our TPA3118 AMP shield (only LR)
Edit: it works as a 2.0 , 2.1 or 2.2
Old 8th August 2016, 09:36 AM   #2
I am including a video of the Purepath so you can see the capabilities of soft. We are able to have 4 poles crossover filters , volume etc for files that are 24/192Khz
https://www.youtube.com/watch?v=fAbiMoIj53o
We send only HPF frequency's over 80Hz (chose from 60-150Hz) to main speakers and rest LPF to subwoofer.
Its hard to explain the sound improvement , but he unit sounds clean , effortless .
ETA to launch Aug 26. Price less than 50$
Old 12th August 2016, 07:06 PM   #3
cph2000 is offline cph2000  Denmark
this looks like a nice little board at an attractive price
Old 13th August 2016, 07:00 PM   #4
dudaindc is offline dudaindc  United States
dudaindc's Avatar
"All measurements are wrong! Thus, measurement is the art of handling errors."
Old 17th August 2016, 07:28 AM   #5
Attached is the LR flow. We are using biquad filters each filter is 2 pole and we cascade 2 filters so totally 4 pole in each channel.
Old 17th August 2016, 07:18 PM   #6
Dimdim is offline Dimdim  Greece
Interesting board!
How do you control volume? Do you use the PCM5142's hardware volume control?
http://www.dimdim.gr
Old 17th August 2016, 07:23 PM   #7
Yes..of course we could use the DSPs volume control but it has no advantage and it takes some DSP cycles
Originally Posted by Dimdim View Post
Interesting board!
Old 17th August 2016, 08:11 PM   #8
sckramer is offline sckramer  United States
sckramer's Avatar
Interesting board!
Good point... how the heck do you control the sub volume?
Scott Kramer - AudioSystem - YouTube - Twitter
Old 18th August 2016, 07:42 AM   #9
there are 2(1/2) scenarios:
Control of sound by DAC (AMP at fixed volume)
In that case both soft volumes can move in tandem (subwoofer can even be specified at % of LR volume)
Control of sound by AMP (DAC at max) .
We suggest to keep the volume of the SUB at a lower level (enough for most situations)..control on LR with your AMP. The sub will only supplement some bass.
most used scenario...we keep the volume of the AMP somewhere in the middle and we control the volume (a bit higher or lower) using 1 scenario.
Old 18th August 2016, 08:24 PM   #10
sckramer's Avatar
Ok
With the default DSP is the LR full range (no xover applied)?
New DAC for RPI with subwoofer out (2.1 or 2.2)Hide this!Advertise here!
RPi 2 with PiFi DAC+ and TDA7297 board noonereallycares PC Based 9 6th October 2016 07:47 PM
Advice / Suggestions WANTED: rPi streaming machine - dac? amp? power supply? festol Everything Else 1 3rd August 2016 05:46 AM
RPi B+ and ES9018K2M DAC: can't get it to work! Feddo Digital Line Level 0 18th April 2015 02:41 PM
Volumio and Rpi DAC tjaekel PC Based 1 5th February 2014 03:34 PM
Copyright ©1999-2017 diyAudio
